    Results 1 to 20 of 23
    Thread: Roof insulation
      Nov 2007
      Lafayette, LA, USA
      Roof insulation
      I searched and could not find any posts on sound deadener specifically for the roof of the car. What is best to put on there for both sound and thermal protection? Or do people leave it be? I have a mixture of Dynomat extreme and second skin luxery liner pro in the doors right now and am slowly working my way around the car.
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
      Milwaukee, WI USA
      I was planning to put Dynamat Extreme under my headliner.
      1969 Camaro SS, 350(NOM), M21, 12 Bolt Posi, 01B (Jan 69) LOS Build
      Nov 2007
      Lafayette, LA, USA
      Do you think there will be any problems with it wanting to fall off due to gravity?
      See my build
      Jason
      Jun 2009
      Cape Coral, FL
      Quote Originally Posted by fordsbyjay View Post
      I have dynamat xtreme on the underside of my roof and this was my biggest concern, unfortunately my project isn't on the road yet so I don't have any real world experience with it, though its been on for about 3 years now and hasn't changed one bit since the day I installed it. I've also taken a heat gun to booth sides of the roof with a thermometer to test what it would do in the Florida summer heat. It held up extremely well in my opinion.
      Oct 2012
      Good prep and it stay up there unless its outside in some really high temps. I had it on my Mazda and it stayed up there into about the 170* mark. The glue holding my interior together, however, did not.
      Nov 2007
      I used dynamat extreme on the roof panel of my second gen TA. 5 years and still holding.
      Ron
      69 Camaro Redfire, thanks to
      Marquez Design | Ring Brothers
      Nov 2007
      Lafayette, LA, USA
      Good to hear. thx
      See my build
      Jason
      Cornettsville, ky
      lizard skin is paint it would work
      Jan 2011
      Ocean Springs, MS
      I've been doing custom car audio for almost 20 years and let me tell you nothing beats the spray in stuff for sound deadening! I did Lizard skin this time around on mine and I'm completly happy w/ it! I did the roof, floor, doors and rear quarter panels. I don't have any pics of the roof but trust me it looks just as good as the floors and it's really easy to clean up. The only down side is you need a compressor to spray it on. 5gal on my 68 did everything excluding the trunk.
      68 Camaro - LS6, Trickflow 220 heads, 224/228 cam, Wilwood 6p front-4p rear, TCI 4-link w/ Ford 9", 4.10's, T-56, Corbeau A4's
      My build pics....
      Connecticut
      Quote Originally Posted by duckmanjbr View Post
      This looks very nice, when you guys do this do you have to plug any of the holes for the seats and stuff? thank you
      Paul Krol
      1968 Camaro
      Feb 2011
      dallas, tx
      I have already por15 my floors. How well does that help with heat and sound deadening? I was still plaining on using dynamat too
      savannah,ga
      Por does nothing for sound deadening, its a rust preventer only.
      Feb 2011
      dallas, tx
      thank you. i guess i will just dynamat the hell out of my car
      Oct 2006
      Saskatchewan, Canada
      I've used lizard skin a a couple of projects, it will go on any future ones also. It can be applied over por 15 if you want, have done that in the past and worked well.
      Loganville, GA
      I used an insulation similar to Dynaliner on the roof of the Camaro, helped out a bunch with heat. It is a bit thick, around 1/2", but I don't have a headliner or anything other than a full cage, since it is an autocross only car.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      The Piedmont Triad, NC
      I'm going to use lizard skin on mine. I just got mine in yesterday and was reading all you need is scuff the surface, shoot, and also seals the metal so no more rust issues
      67 LeMans Convertible
      67 GTO
      69 Camaro Build Thread https://www.pro-touring.com/showthre...ost-Money-quot
      70 Chevelle 400 4spd
      70 Chevelle
      Aug 2003
      Byhalia, MS
      Dynamat and all the competitive brands are not sound deadeners, persay, they are vibration dampeners. They need to be used in conjunction with an actual sound deadener. Ensolite or the dynaliner are actual sound deadeners. Mass loaded vinyl is as well. My build has and will be utilizing Dynamat xtreme along with Ensolite closed cell foam with mass loaded vinyl under the carpet.
      Nov 2007
      Lafayette, LA, USA
      Quote Originally Posted by makoshark View Post
      I used dynomat extreme in the front doors with a layer of Overkill Pro on top of that. I have enough to do the rear side window sections as well. For the floor I am planning on using Damplifier pro with a layer of Luxury Liner pro (which is very heavy..). I couldn't imagine adding all this weight to my PT car, thankfully this is my hotrod and I am looking for quiet cruising.
      On the roof I am not sure what I am looking for. Obviously some vibration & sound dampning as well as some thermal help. But I don't want all this to be 2" thick and collapse the roof of my 56 because it weighs 200 lbs. There is no roof bracing at all in this car. Am I right in understanding that the dynamat extreme does not need to be 100% cover and only strips will do?
      See my build
      Jason
      Milwaukee, WI USA
      ... Am I right in understanding that the dynamat extreme does not need to be 100% cover and only strips will do?
      That is correct. It is actually a "vibration dampener".
      Feb 2011
      Maple Ridge, BC Canada
      I used the Eastwood Thermo-Coustic Sound Deadener Material for the floor and Dynaliner for the roof.
      Car is still LOUD!!!
