    Results 1 to 8 of 8
      Pensacola, FL
      Need tuning advice
      Running 670 street avenger on mild 350. Roller cam, vortec heads 700r4 trans, stock stall. I have a slight hesitation that occurs in only one situation. From a dead stop under any amount of throttle, its perfect. While cruising down the road at steady speed or coasting, there is a slight hesitation when you step on the peddle. If you ease on the gas it is not noticeable. The more aggresive you are with the pedal, the worse it gets. I have replaced the acc pump squirter with a larger size. Off idle response was noticeably improved, but the cruise hesitation is still there. Do I step up again on the squirter? Different power valve? Any help is appreciated.
      Scott
