    Results 1 to 19 of 19
      Hub Centric Rings?
      Does anybody know the correct hub centric ring to use when mounting a BMW wheel on a 68 Camaro? I'd like to get these ordered so they'll be here when my wheels come in.
      Thanks!!
      GeoffP
      68 Camaro - LS1/T-56
      Oregon
      That would depend on what you're mounting them to...factory drum hubs? OE discs? Something aftermarket? The most common BMW center bore size is 72.5mm if I recall correctly, where the standard GM wheel pilot dimension is 70.5mm for the older application, 70.3mm for the newer ones. I take it you're not accounting for the 5x120mm wheel pattern mismatch?
      Tobin
      KORE3
      It's what I does.
      Yes sir - I bought a set of PCD correction nuts but want to make sure the wheel is properly centered. The sizes you listed are the same as I found elsewhere. I was looking at the front hubs on my car tonight - they're the billet Wilwood hubs so they are not a consistent diameter. I need to buy a caliper to I can measure it both front and rear hubs so I can get it right.
      GeoffP
      Oregon
      The Wilwood hubs have a tapered snout and are not intended for hub-centric wheel fitments.
      It's what I does.
      Feb 2006
      Tennessee
      What wheels did you buy?
      Kerry
      66 Chevelle - LS-Leap
      LQ9 / T56 Complete - Phase 2 in process!!
      https://www.pro-touring.com/threads/...t-LS-Heap-quot
      SC&C, Kore3, Detroit Speed, BBS, Advanced Induction, TickPerf, Currie, Moser, Holley, Hellwig, Edelbrock LS-Kit, Mast, Wilwood, BP-Automotive, StopTech, Ridetech, Hotchkis, UMI, Energy Suspension, AAW, B&B Classic's, PPG, Aeromotive, Canton, C&R, Sparco, Ididit, Spectre, Bridgestone, DakotaDigital, Alpine, RockfordFosgate
      I bought a set of Beyern "5"'s - hope I didn't make a mistake! Guess I'll know tomorrow.
      GeoffP
      Feb 2011
      It will be tricky with the Wilwood hubs. You could make a custom tapered hubcentric ring.
      But frankly it would be best to redrill the wheels or get a set of hubs that has the correct bolt pattern.
      I fit one of them last night and spun the wheel around. I didn't see any visible wobble. I'll feel better when I can get the PCD correct nuts to see if I can get the wheels properly centered on the front hubs. If not, then a call to Wilwood is in order to see if they can do a custom drilled 5x120mm hub.
      GeoffP
      Aug 2013
      Country Flag: Jamaica
      @Geoffp were did you buy the corrective lug nuts from been searching for months .yours or any other member response would be greatly appreciated thank
      Quote Originally Posted by kaine876 View Post
      I bought them through eBay from an overseas vendor. They were expensive. What's bad is that I didn't end up using them at Wilwood's request. Their technician told me they are not necessary as long as the bolts are kept torqued. I have checked the torque several times and found no loose lugs (so far).
      GeoffP
      Aug 2013
      Thank u i will finally get to put my rims on ,did you use stock lugnuts or aftermarket ..one more question .was there any different material used to make ur lug studs from a factory stud on 1994 sonoma that u know off
      I used aftermarket lug nuts. My car has 1/2" studs front and rear. I am fairly certain all 4 wheels have ARP studs. I know the fronts do because they are screw-in ARP studs provided by Wilwood with their hubs. The rear came from Moser already pressed in with the axles I bought for my car.
      GeoffP
      Aug 2013
      thank u for the info thought u had them on stock studs....and nice camaro hopefully i can get my hand on a ls1 for my s15 1 day
      You're welcome. I am always glad to help if I'm able. Thanks for the compliment! I enjoy it as often as possible. Keep your eyes open...there are deals out there to be had if you're patient.
      GeoffP
      Aug 2013
      Quote Originally Posted by GeoffP View Post
      I would too .....alright i will keep looking and ill be back with more question thanks again
      Aug 2013
      Do you still have the pcd corec lugnuts,if u do are u willing to sell
      Jun 2006
      Katy,TX
      So how do lugnuts change the variation in the diamter of the stud bolt pattern?
      1965 GTO project car
      2004 Pulse Red GTO
      PCD corrective lug nuts have a captured washer that is the cone end of the lug nut - this washer end nut allows for minor bolt circle variations.
      GeoffP
      Jun 2006
      Katy,TX
      Thanks for the explanation.
      2004 Pulse Red GTO
