      Nov 2004
      Colorado
      t56 install questions
      Further issues with the POS kit I bought from K@#$%^)r.
      The trans seems to be at more of a down angle than I need. I seem to recall that proper angle is achieved when the trans mainshaft is parallel with the subframe rails. Is this correct?
      I think I might have to cut the crossmember and move the center of it up about 3/8" to 1/2" floor clearance is not a problem as I have raised the trans tunnel.
      La La Land, CA
      Trans angle should be in the rage of 2-1/2 degrees down. You will need an angle gauge to get this reading, but when measuring make sure you:
      Take a measurement off the frame
      Take a trans angle measurement
      Subtract the difference between the frame rails (Should be level) and the trans, to get a 2-1/2 down angle.
      Our crossmember already has this built in.
      Tyler
