    Results 1 to 17 of 17
      Albemarle, NC
      Hardcore cooling system design questions
      so, im planning a radiator change. needs to be a very heavy duty and robust cooling system. im looking for the level of overkill that equates to killing a small spider with a 20 lb hammer.
      im planning aluminum to reduce a little front end weight. will be bolted to the core support, so no rear mounted radiator ideas.
      also planned on running dual electric fans with a shroud.
      so, my options are plentiful. theres a couple of bolt in three core aluminum radiators, some 4 core, and all the way down to single core. all bolt in. i can get a little more creative with non-bolt in, and come up with a bunch more options.
      so, my decisions come down to how many rows?
      crossflow or downflow, and why?
      offset inlet/outlet, or inline inlet/outlet, and why?
      what will provide the maximum amount of cooling for a given radiator opening/fan cfm/core size?
      i know that theres probably a lot more to it than this, but first step is radiator. then on to water pump.
      water pump will be belt driven for reliability. serpentine reverse flow small block chevy. im thining aluminum water pump, but i doubt the weight reduction for the amount of money will not be worth it in this case over cast iron. im looking for maximum dependability, and agin, maximum cooling.
      i was thinking using a late 80's truck water pump with the heavy duty cooling options. any better ideas?
      anything i should consider with hoses? anything that would make the cooling system more robust and effective other than hight quality molded gates hoses?
      and yes, im overthinking and over engineering what should be a buy bolt in parts and put together job. i plan on playing with twin turbos on this thing at some point.
      Michael Crawford
      Jun 2010
      Georgia
      For rows, you need to consider a thickness equivalent to 4 core if you are going to autocross. What do I mean by that? Well, 4 core is an industry standard term that related to 4 cores of brass & copper style radiator with each core measuring 1/2" thick. Now, that has to be clarified for aluminum, as aluminum radiator cores are 1" thick each. So a 2-core of one of our radiators is the same thickness as a traditional brass & copper 4 core. That means 2" total core thickness.
      Rows: you want a good row / fin count, but remember that if you get too dense on the fins per inch, the air flow will slow down as it passes through, which means it heats up more and doesn't cool as well.
      Crossflow versus downflow: the crossflow is the industry standard now, and allows for a larger core from side to side in most cases. Both styles can cool adequately if there is enough air flow over the radiator. Most cars though have a wider opening from side to side than they do top to bottom.
      Inlet/Outlet: you simply need them to be placed on the correct side of the radiator for your application. If you have an LS engine, you want them both on the passenger side. If SBC or BBC, etc., just make sure they match your inlet/outlet on the engine.
      Fans: get the biggest and best you can afford.
      Oct 2009
      New Derry, PA
      Sparky is 100% right about a thicker core being the industry standard for "heavy duty" cooling. Frontal area is also important, as the air is less efficient as it passes from one row of tubes to the next; so the more surface you have exposed to incoming air, the more efficient the radiator will be.
      Funny, I've kind of been on a rant about cooling lately since I've heard so much bad information around about how the cooling system works...
      The first thing I'd like to address is DON'T GET HUNG UP ON HAVING "LOW" WATER TEMPERATURES. As long as the system is not puking water out, temps in the 220 range are nothing to be concerned about; IF the system will maintain those temps constantly. I point this out because people make a lot of bad decisions based on that gauge on the dash. Low water temps do NOT always mean the cooling system is doing a good job of protecting the ENGINE.
      What you really need is high block pressure, and plenty of contact time for the coolant to transfer heat out of the metal. Block pressure keeps steam pockets from forming, and "mashes" the water molecules against the metal to improve heat transfer. A "High Flow" water pump is about the most worthless thing you could possibly put on the engine. The thermostat (or restrictor) is going to slow the flow down anyway, right? The best water pumps are the ones that have an enclosed impeller and very tight internal clearances. The more heat we can pull out of the metal, the higher the temperature of the water that will be coming out of the engine. Since the block outlet is where most cooling systems measure coolant temp, that higher temperature might just be a good thing... What we really need is another gauge, so we can measure the temperature of the water going back IN to the engine. We should be seeing a minimum 50deg drop in water temp across the radiator under full load conditions. Anything less than full load the thermostat will take care of automatically.
      Oct 2012
      Physical fan size isn't as important as CFM air flow. A good 12" fan can move more air than a crappy 16" fan.
      Jun 2012
      South Lyon, MI
      Remember that in thicker radiators the rear cores are less efficient because the air is warmer from the leading cores. Thicker radiators may not always be the best.
      One option is a double or triple pass radiator that has a longer path for the water to flow through. This will cool the water more than a single pass if all else is equal.
      My question to you is, "what problem are you trying to solve?" Most cooling problems that I have seen were a result of: 1) faulty cooling system components; 2) improperly tuned engine; 3) Improper airflow through the radiator; or 4) scale or crud build-up inside of the block and radiator. If you have a problem, check these issues first. Don't fix a problem that does not exist, or ignore the real problem while spending money on a phantom issue.
      Ask yourself some hard questions before you make radical changes. You may be happier in the end.
      As always, Ray knows his stuff. Sparky does too.
      Albemarle, NC
      othern than minor leaks at the core, i have a bad fan clutch. thats the only cooling system problems that have cropped up on this build so far. but then again, ive only put 10 miles or so on it....
      i have to replace the radiator due to the leaks. right now nutmeg is stopping them so i can drive the car, and its cold enough that the bad fan clutch isnt causiong me problems. putting in a shrouded dual s blade fan system over the weekend, with a thermostatic controiller. this was a setup i used on my 435 horse at the wheels duster for many years. proven reliable and quality. i believe origonal application was a chrysler k-car. this is temporary while i plan out the most robust cooling system possible. again, i dont want to spend money twice if i can help it. the build consists of AC, PS, PB, EFI, ODAT, an oil cooler, and a large trans cooler. power steering cooler as well. i want thins thing to be bullitproof for way more than i plan to throw at it, because my projects tend to snowball considerably once i think theyre done. ive always wanted to play with twin turbos, so im actually building the rest of the syetems to handle the added heat and strain well before i buy the hair dryers.
      does that help? body is 64 chevelle, traditional small block.
      Michael Crawford
      Oct 2012
      British Columbia
      There are also options like adding oil and P/St coolers to your rad as well if that is a concern. When I built my S10 I cut and adapted my rad support so the rad was recessed into it so from first glance it didn't even appear to have a rad. It was kind of neat looking and with an S10 room is at a premium. Please post some pictures on whatever you decide to go with.
      Good luck.
      Todd
      '14 ZL1, 6 speed and 6.2L of Super Charged Awesome!
      '67 Camaro SS in process. A long, slow, expensive trip...
      How hard can it be...
      Project Obsession
      https://www.pro-touring.com/showthre...ject-Obsession
      Oct 2009
      New Derry, PA
      Also, you mentioned turbos. Plan your build so you don't have to just slap an intercooler in front of the radiator. At that point, all this high brow stuff goes right out the windah...
      Jun 2012
      South Lyon, MI
      Then I would review double or triple pass circle track radiators. Aluminum versions are available from various sources and should be nearly bolt in. Double pass radiators require you to put a thermostat housing to route the upper hose to the opposite side of the car. Triple pass radiators have the same orientation as a traditional single pass.
      I think your best bet is still good fans and ducting. Make sure you lay it out so the intercooler is not heating the radiator cooling air.
      Wake Forest,NC
      I would talk to C&R radiator for help, I had them build me a radiator for my car with built in p/s and engine oil coolers and I couldn't be more satisfied with it's performance. The under hood air temps with turbos will be just as important to manage as the cooling system.
      Oct 2009
      New Derry, PA
      Since you are upgrading the rad, cut out the core support as much a possible to allow more surface opening. Double pass is a great idea, especially if it works out for your hose connections anyway. Many racing setups pull a #8 line from each corner of the intake manifold, rather than using the large upper rad hose (no thermostat obviously). This helps keep the water from "short-cycling" back to the front of the engine. You can buy the rad with 4 #8 connections for the inlet side, or make a custom water manifold to bring them all back into a single large hose if you want to run an inline thermostat. This pic of a sprint car engine is a good example of what I'm referring to.
      Aug 2012
      Subic Philippines
      Country Flag: Philippines
      http://www.pirate4x4.com/tech/billavista/Cooling/
      "The cooling system – deceptively simple yet devilishly complicated. Like many things – your rig’s cooling systems is one of those things that seems simple, that most people think they understand, but which, behind the scenes, is actually a lot of fairly complicated stuff working together in a fine balance. Or not working together well – which is often the problem."
      Lars in Philippines
      Jun 2012
      South Lyon, MI
      Quote Originally Posted by exwestracer View Post
      I like that setup. I have the fittings for 4-corner cooling on my intake. I need to look into this. Thanks Ray.
      Southern Indiana
      YESH, do I have to KEEP repeating some real facts and fixes?
      OK look for radiator that is large enough to at least resemble the stock size. In aluminum look for a rad with at least 2, 1 in tubes, or 3, 3/4 in will work. Any more and you get reduced flow. double and triple pass rads are,,,,well crutches unless your frontal area can handle that 2 part or 3 part rad and the 1/2 or 1/3 is about 2/3s of OLD rad area.
      IE if you have enough air flow AND exhaust you can cool a 350 V8 with same rad as a 2.0 4 cyl non AC Ford Ranger,,,,,ask me HOW I know this!
      Now also go look at www.evanscooling.com,,,,read up on NPG+.
      Non-aqueous Propylene glycol, boiling point 375F deg, NO PRESSURE. Ethylene Glycol and Water still boil in the 212F deg range UNLESS UNDER PRESSURE.
      Pressure raises boiling point 3 degrees for every 1 lb of pressure, oh and boiling point goes DOWN as altitude raises.
      Think about this one, had a guy dirt burning, had an 080 over 350, ran 240-250 with water,water wetter, EG/Water, any combo you want,,it RAN HOT, 31 in wide rad, 3 rows, big fan(S) ,,,nothing cured issue. Till I got into selling this stuff to few local drag racers.
      We got 2 gal of flush, he replaced unteenth set of head gaskets(guessing).
      We dropped drains on block, poured in the flush from another guys change over , then HIS 2 gal, then redrained block.
      Poured like 2 1/2 or 3 gallons of straight NPG+, installed a 195 t-stat, 4 lb cap, reset fans to come on at 225F.
      He started it and it took it over an hour with only his old 2 row aluminum rad to get hot.
      Well hot enough to cycle fans couple of times.
      He ran it rest of year and had ZERO cooling issues, and then sold long block to local farmer for grain truck aluminum rad and all and never opened system except to hook up heater ,,,That truck NEVER has gotten hot no matter what he did with it
      And with the coolant not having any water in it, it wont corrode like EG/Water.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Jun 2010
      Georgia
      as an update, we now have a bolt-in radiator for the 67-76 mopar A-bodies (Early Cuda, Dart, Duster, Demon, Scamp and Dart Sport):
      http://www.rndfabrication.com/MoparAbody.html
      We did the prototype unit for Eric Wracker's blue Duster that is competing for Muscle Car Of The Year award. Beat the snot out of it on the track and never went above 185
      Belle Plaine, MN
      You can help cooling issues a lot if you build the engine with internal coatings and control where the heat goes.
      There are porcelain coatings to prevent heat from leaving the combustion chamber- they go on the piston tops, in the chamber, on the valve heads, and inside the exhaust port. I also like to coat the inside of the intake port to insulate the incoming charge.
      There are graphite-based anti-friction coatings too- they minimize friction (and heat) and can even add a little power. I like to have the piston skirts, rod bearings, main bearings, and valve springs coated with it.
      You'd be amazed how much cooler a coated engine runs. There are other advantages too- the coated chamber allows you to run an additional .5 point of compression without worry. It smoothes out the sharp edges where hot spots can form, and also spreads the heat out over a wider area so the chamber maintains a more universal temperature overall.
      Lee's suggestion to run Evan's coolant neglects to mention one crucial point- once you choose Evans coolant, you can't add water or any other kind of coolant. You must run 100 percent Evans coolant. The stuff works but it's quite a commitment.
      Start your cooling efforts at the source- inside the engine!
      Scott Parkhurst
      Aug 2011
      North Platte,NE
      I have 3 different radiators in my car first was a Griffin 2x1" core universal didnt cut when pushing the car no mater how much fan, 2nd was a Northern 2x1" dual pass, had no advantage over the Griffin. Now im finally happy with a Griffin Nascar draft 2x1.5" core radiator. It works like it should and keeps the engine on the 180 thermostat until it get HOT out like 95+. I ran my car for 15 laps on a road course and it just hit 220 by the end. I would have to let the car warm between autox runs I bet. The only bummer is this thing has a 3" thick core.
