      Jun 2010
      Deployed
      O-Ring Installation/Uses
      I took adapters off my Wilwood hydraulic clutch MC and noticed there was an O-ring on the NPT fitting for the remove reservoir. The interesting thing, this O-ring is too wide to be internal. Seems it was used more as a gasket. Is this a proper use of an O-ring? I was thinking maybe the OD should be smaller and fit around the ID of the hole. Thoughts?
      1970 Camaro/DSE build
