      Feb 2011
      Virginia Beach, VA
      Header / Steering Box Interference
      Does anyone make / sell really tight 90 deg Power Steering Fittings for a GM Steering Box? I am trying to gain some much needed clearance for a set of 2" Primary x 3 1/2" Collector Custom Headers on my Omega. No "Off The Shelf" Big Block Olds headers made for these cars, so I don't want to tear up the ones I had made. The raised port RR/Wenzler Heads have the headers moved up and out a bit from the location on the stock heads the Headers were made for.
      Jun 2011
      St. George, Utah
      As a big time X body fan I'd sure love to see photos of this car! Sorry all my cars have had SBCs, so I've never had to modify lines.
      SRD on Facebook
      79 Cutlass wagon build
      Oct 2009
      New Derry, PA
      Might take some fiddling, but I think you could get away with using banjo fittings at the box, and AN flare adaptors to run to your hoses.
      This photo is for a different application, but shows what I'm referring to pretty well.
      Houma, Louisiana
      I had the same problem with my 572 engine header power steering box clearance on my Nova. You can bend the 90 degree fittings a little to gain some more clearance without crimping the fittings. I was and am still thinking about raising the engine up a little with shims under the mounts to gain a little more room as I definitely do not want to modify my headers. I had originally ordered a new 670 ps box modified by Tom Lee but that would not ever come close to fitting with my headers so I installed a reman 12.7 800 box I got from Oreilly's. Right now I have about 1/8" to 3/16" clearance at the one header pipe that passes right over the fittings, I installed some heat shield tubing over the fittings and hose to help with the heat. So far everything has been good.
      Bill Haynie
      1970 Nova 572/620 TKO600
      2013 Boss 302 Laguna Seca
