    Page 2 of 2 FirstFirst 1 2
    Results 21 to 33 of 33
      Jun 2020
      Arkansas
      Reviving an old thread to see if there something out there I’m missing. I’m using the 4L80 with the gm C&C TCM and harness. Dakota digital gauges. Getting the gear selection is straight forward but I’ll be using a Lokar bump shifter and I’m looking for a way to display the actual gear the trans is in. The Lokar Sport Shifter I’d like to use has PRND +/- so there’s no manual 1st gear selection through the lever.
      Mike
      69 Camaro - In the Works
      Quote Originally Posted by AEH View Post
      Does the C&C TCM have the ability to use the tap shifter? The 4L80e also used a gear position switch. It bolts to the side of the trans and when used in an OEM application it would show what gear the shift lever was in on the dash.
      Jun 2020
      Arkansas
      It’s been a while since I read the literature but until you asked I was confident it does. I’ll read thru it later but still pretty sure it does.
      Mike
      Jun 2020
      Arkansas
      From the literature:
      SuperMatic Transmission Control System Works With 4L80-E
      Optional features for personal preferences
      – Gearshift timing
      – Multiple shift patterns
      – Manual shift mode
      – Supports most “Tap Shifters” or wheel-mounted paddles
      – On-Board data logging
      Mike
      – Gearshift timing
      – Manual shift mode
      Did they include a wiring diagram? The Lokar is pretty straightforward for wiring.
      Jun 2020
      Arkansas
      Yes. Wiring the shifter is simple. I’m looking for a way to display the actual gear. If I use the Lokar there is no physical position for first, second etc gear. Only drive and the manual bump shift. Dakota digital states that the connect & cruise system does not broadcast the gear selection via obdii. I’m hoping someone has found a solution.
      Mike
      This is where you would use the gear position sensor that bolts to the side of the trans.
      Jun 2020
      Arkansas
      Thanks Again. That would take care of PRN&D and that’s doable multiple ways, but that’s not my question.
      Mike
      Then I'm confused what you're asking.
      Jun 2020
      Arkansas
      Is there a way to display the actual gear the transmission is in. ie. 1st 2nd etc. Park, reverse, neutral and drive are physical positions, easily determined by the position of the shaft. When in manual mode, there will be no indication whether your in 1st or 3rd. Not that that’s a huge deal, but if there is a way to get the gear selection information from the ECM/TCM, it’d be nice to have. It’s in there.
      Mike
      Your controller should have a commanded gear channel. This information should be available over the CAN bus.
      Jun 2020
      Arkansas
      Figure out how to get it out of there for me then.lol. That’s my question.
      Mike
      Various companies make OBD2 interfaces that can display data. Look at PCS. They have a paddle shifter with a display. They may sell just the display.
