      Austin, in the great Nation of Texas
      Vacuum Booster Question
      Trying to trouble shoot the Baer 4 wheel disc setup on my newly (or nearly) finished '68 Camaro. Brakes are bled, lines are solid, yet brake pedal goes almost to the floor and require a LOT of pedal pressure to stop the car. With vacuum line disconnected, pedal is high and hard, but I've not driven the car that way. Don't know the bore but the master cylinder is the one supplied by Baer for this system, so I'm assuming it's correct for the 2 piston PBR calipers. Booster is a 9" single diaphragm.
      So here's my question - how much engine vacuum is required for the booster to work effectively?
      What else should I be looking at?
      Thanks!
      John
      Jul 2011
      SFV In So Cal
      I've read 10-20" of vacuum depending on what booster you have
      Benicia, Ca.
      The master that used to be supplied by Baer is too small of a bore! On a 9" single we typically run 1 1/8" master.
      We have several from $49-195 for a NICE bolt on lid
      If i can be of any help send me a pm!
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
      I have 10.5" vacuum in gear and 14-15" in P. I run the tuff stuff 9" dual diaphragm booster that DSE uses with their kit. I have a Wilwood master and Wilwood brakes. The booster works great. In fact I am having to get used to the lighter pressure to stop the car.
      Benicia, Ca.
      Typically we like to see no less than 15" steady at idle to run a booster.
      Matt
      Benicia, Ca. 94510
      866-628-8746
      www.mcbparts.com
      Jun 2006
      Katy,TX
      My factory 79-81 Trans Am 4WD dual diaphragm booster works good 10" and above getting around 9" at idle gets iffy intermittently.
      1965 GTO project car
      2004 Pulse Red GTO
