      Oct 2012
      Poly and Johnny Joint questions
      I am happy to say I finally have my triangulated 4-link set up where I wanted it! Now I have a few questions regarding the joints.
      1. Is there a recommended torque spec for tightening a poly joint and/or Johnny Joint?
      2. Should the steel tube (can't think of it's correct name) that your bolt goes through be the same width as the poly? A couple that came with my kit are shorter, and I'm thinking it will "wedge" my poly.
      3. Anything else I should know?
      I'm going to pull my suspension apart and fully weld my brackets, thought this would be some good info to know. I tried to search with no avail, I haven't had much luck with the search engine here yet.
