    Results 1 to 11 of 11
      May 2012
      Boston, MA area
      Modifying my front suspension and tires- effect on steering.
      On our project we are using +2" wider suspension set up along with wider tires and wheel package most likely with less back space or more offset from the normal. The tires overall height is taller than the original size also.
      The car is a GT40 midengine setup, total weight of the car is around 2400-2750.
      What effect on the steering will this have?
      Will this make the steering stiffer? We looked at a power steering unit for the car, but have been to we most likely will not need it. The power steering unit is speed sensitive and adjustable. Our biggest concern is at lower speeds around town.
      Building cars or any project must be fun first. If not it turns into a job.
      We build cars for the fun and enjoyment of it, it is a family time things.
      So if the fun stops, the build stops.
