      Jan 2013
      14 circuit fuse block
      Kwik The TR-1400 Replacement Fuse Block
      14 Pre-wired and Fused Circuits
      High / Low Beam
      Parking Lights
      Gauge Power / Interior / Dash Lights
      Turn Signal / Hazard Lights
      Brake Lights
      Horn / Cooling Fan Circuit
      Ignition/Coil/Distributor
      Starter Circuit
      Charging / Alternator Circuit
      fuel pump
      Radio / Accessory (Constant Hot)
      Radio / Accessory (Ignition Hot)
      AC/Heat Power & Fan
      Pre-wired Neutral safety
      14 ATC Fuses
      Pre-wired Flasher Unit
      Pre-wired Hazard Unit
      Pre-wired Horn Relay
      Compact easy to hide design
      Pre-wired turn signal circuit
      Connections in block are crimped and hand soldered
      Aluminum Base
      Brushed Aluminum Fuse Cover
      Wires labeled by circuit & colored to match GM factory wiring codes
      Instruction Booklet
      List Date: 1/26/2013
      For more info, click here to view the original listing: 14 circuit fuse block
      On Sale For: $80 + $0 Shipping
      Retails for: $125 | You Save $45 | That's a 36% Discount!
      Jan 2013
      To the top. Really nice fuse block for hotrod build or to upgrade old style fuse block
