      S.F. Bay
      C5/C6 upper control arm dimensions
      Looking for the dimensions of a front upper control arm for a C5/C6 corvette.
      *ball joint center to bushing centerline.
      *center of bushing to center of bushing
      Des Moines, IA
      in the upper right hand corner you will find the search box. Please use it as this has been discussed a million times.
      S.F. Bay
      Prior to posting, I did use the search function, I did find a posting where they stated the length looking straight down on the car, but I'm not sure at what ride height that was at. That's why I'm asking the questions.
      Mar 2012
      On ride height. Im sure it was stock. If its slammed, the a arm would be slightly longer and ball joint angle would change. Prob does not help. Just thought i would throw it out there.
      S.F. Bay
      Found this info previously, not sure if this was at ride height?
      Front UCA/LCA Length (BJ Pivot to bushing centerline):
      UCA: 8.55"
      LCA: 15.96"
      UBJ to LBJ: 12.614"
      those measurements are from a top view
