      May 2012
      Thousand Oaks, CA
      1st Gen Camaro Bulkhead Connector
      Does anyone know if someone sells just the bulkhead connector of the engine/lighting wiring harness?
      My harness is a mess, but I want to make some modifications, so I don't want to spend $125 on a new harness, just to hack it all up.
      shawn
      Melbourne, FL
      MIght want to contact these guys and see if they can sell you what you need. http://www.wiringharness.com/
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Apr 2004
      Cedar Rapids, IA
      I don't get your question. Your bulkhead connector is the back of your fuse box for your under dash harness.
      What kind of modifications are you going to make? M&H will do several types of modifications to their standard harnesses they sell like internally regulated alternator and HEI setup.
      Newbury Park, CA
      Try American Autowire. They may sell you just the bulkhead connectors.
