      Cincinnati, OH
      What looks better?
      I guess the reason guys are staggering 18's on front and 19's on back is tire width availability in the 19 inch size. I am tubbing and wonder if we want to try and get an equal amout of "tire sidewall height" in front and back. Or total tire diameter. If I went with 265/35-18 in front on a 9" rim and 305/30-19 on a 11" rim in back I would have around the same height side wall but a one inch OD smaller tire in front. If I went with a 265/40-18 in front I would have about the same tire OD front and back but about a half inch more sidewall height in front. Would that look weird? What are you guys looking for?
      Jim S.
      67 RS
      "driver "
      Beach Park IL
      If there is a difference of 1" in your wheel diameter then there should be at least a 1" difference in overall diameter. Using the same overall diameter with different sized wheels will make the smaller wheel look way smaller than it really is.
      So yes, matching sidewall height is what you are looking for.
      Donny
      Cincinnati, OH
      I like as much sidewall as possible. But matching makes sense..
      Jim S.
      67 RS
      "driver "
      Port St. Lucie FL
      use this to help and post up screen shots of what yo are trying to do
      http://www.newstalgiawheel.com/wheel_visualizer.asp
      Kacy
      79 Corvette, 406 SBC, Holley EFI, 700R4
      Hello, what tire and wheel combo did you end up going with? Thanks in advance.
      Feb 2007
      Tinley Park, IL
      Quote Originally Posted by beyonda68 View Post
      FYI The gentlemen who posted the original question has not been active here in 6 years.
      Nick ~
      1969 Cutlass
