Results 1 to 20 of 46
Thread: 1971 Trans AM 455"LSX Project
- Aug 2004
- 175
We purchased this clean Pacific Northwest Lucerne Blue 1971 Trans Am clone, as a nearly completed project. We wanted to take the already nice body and chassis restoration to the next level. We started by pulling out the old school Pontiac drivetrain, and disassembled most of the car. We then rebuilt, blasted, painted, and coated nearly every part on the car. We further detailed the undercarriage to brand-new condition.
For the new powertrain, we chose to run a Texas-Speed 455" LSX short block, topped by PRC LS7 heads, and our Speed Inc LS7 street cam. GMPP LS7 intake, Holley throttle body, and LS7 injectors are used, along with new black nylon braided lines running back to the Spectre EFI tank modified with the addition of an Aeromotive 340 in-tank pump. We used 1 7/8" Dynatech headers, along with a Pypes 3" stainless system and stainless Flowmaster mufflers. An FLT built GM T56, modified with a Ford T56 tailshaft and housing, which allowed us to utilize the original 4 speed floor hole. Less cutting is always better. We mocked up the original shaker, but we will be modifying a Protouringfbody.com shaker base, so we can be sure to get the scoop in the precise location to appear original when the hood is shut. We rebuilt the original 8.5" 10 bolt and added a Motive 3.90 gear. For braking we chose to go with a Kore3 C5 conversion setup. We used Dirty Dingo mounts, and modified an original trans crossmember to aid in getting the shaker location correct. Standard, but "refreshed" 98-02 F-body drive accessories worked perfect.
Stock shaker mocked up
The interior will be factory original appearing, will all gauges functioning. It will be complete once it returns from the body shop. We chose Year One 17" honeycombs with Nitto 05's for wheels, and rest assured, we will get the suspension lowered once we have all the weight back in the car.
Some images of the fresh paint, and decals installed, ready for final assembly
