    Page 4 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
    Results 61 to 80 of 244
    1. #61
      Aug 2009
      Quote Originally Posted by GNon18s View Post
      I just googled "Vintage air Heat defrost" and it popped up right away. Its only like $230 from summit. I do not have pictures but I mounted mine under the dash (behind the stereo area). It would be pretty easy to mount it directly to the HVAC block off plate. Its small!Attachment 70082
      Hmm, so in that case, why isn't the blockoff plate flat? I assumed that there was a reason for the raised area (That it was needed for the heater for some reason).
    2. #62
      Sep 2007
      York, Pa
      The plate on the firewall was made that way for aesthetics only.
      Justin Snow
    3. #63
      Aug 2009
      Got it.
      Well, it looks great! Looking forward to more updates!
    4. #64
      East, Tennessee
      I love it! Your doing a fantastic job and I can not wait to see it at a RTT event soon...
      1986 Buick T-Type
      RideTech, DSE, BAER Brakes, Forgeline Wheels, LED lighting, More!
      * Get your Top of the line GPS Theft recovery devices Here!
      www.GNSperformance.com
    5. #65
      Sep 2007
      York, Pa
      Quote Originally Posted by xxxturbo6 View Post
      i can not wait to see it at a rtt event soon...
      x2!!
      Justin Snow
    6. #66
      Sep 2007
      York, Pa
      I finally got around to working on the frame. The first thing I did was box the side rails with 1/8" plate.Name:  frame box cell1.jpg
Size:  220.5 KBName:  frame box cell2.jpg
Size:  256.4 KBName:  frame box3.JPG
Size:  200.3 KBName:  Tig weld frame.jpg
      Justin Snow
    7. #67
      Sep 2007
      York, Pa
      Had a friend help roll it outside and degrease power wash.Name:  frame degrease.jpg
      Justin Snow
    8. #68
      Sep 2007
      York, Pa
      The first part of this project I outsourced so far was having the frame sand blasted. For some reason it took the guy five weeks to blast the frame and it made me wish I had just bought a cheapo blaster and done it myself. Oh well, the frame did look good when I got it back in bare metal!Name:  bare frame.jpg
      Justin Snow
    9. #69
      Sep 2007
      York, Pa
      I sprayed the frame in two coats of SPI epoxy primer, then sprayed the front part of the frame with Eastwood ceramic chassis black. I left the back part of the frame in primer because I still have a lot of cutting/welding to do back there. The front half is ready for some assembly.Name:  Mohawk epoxy.jpg
Size:  151.3 KBName:  frame black.jpg
      Justin Snow
    10. #70
      Oct 2007
      NIce... you need one of those GForce cross members though :-) Really nice work on the firewall!
      67 Camaro In progress
    11. #71
      Sep 2007
      York, Pa
      Quote Originally Posted by XLexusTech View Post
      I guess it depends on how I need to route any future exhaust system the car might have. The Gforce cross member has a provision for true dual exhaust, correct?
      Justin Snow
    12. #72
      Sep 2007
      York, Pa
      Working on getting the new front suspension and brakes together. I'm running SPC uppers and lowers, along with ATS spindles and single adjustable Varishocks.Name:  New control arms.jpg
Size:  176.8 KBName:  Spindle Varishock instagram.jpg
      Justin Snow
    13. #73
      Sep 2007
      York, Pa
      I went with Wilwood W6A front brakes. They are 14.25" rotor with 6-piston calipers.Name:  BIG brake instagram.jpg
      Justin Snow
    14. #74
      Sep 2007
      York, Pa
      Name:  Brakes vs old.jpg
Size:  163.4 KBName:  Safety wired brakes.jpg
      Justin Snow
    15. #75
      Sep 2007
      York, Pa
      I stayed with the traditional coil spring in the front for now (as opposed to a coilover). The springs are eibach and they were previously on the car but I never ran a good shock with them like the Varishocks I will have now. We will see how they do.Name:  full suspension rear.jpg
      Justin Snow
    16. #76
      Jan 2013
      Beaverton, Oregon
      You make tubbing look too easy. Kinda funny the trunk hinges got in the way...
      Nice build. It is cool you have the car for so long.
      Air/Hydraulic tube benders, Drill Press Reduction Kits, Die Sets, Tubing Notchers! All made in the USA
    17. #77
      Aug 2012
      Pennsylvania
      Very nice build!!! Subscribed....
    18. #78
      Sep 2007
      York, Pa
      Started building frame rails to match the OE frame profile.Name:  Frame template.jpg
Size:  224.1 KBName:  Frame plate.jpg
Size:  178.5 KBName:  Frame rail 1.jpg
      Justin Snow
    19. #79
      Sep 2007
      York, Pa
      Name:  frame build2.jpg
Size:  243.3 KBName:  frame build3.jpg
Size:  281.8 KBName:  Frame rails finished.jpg
      Justin Snow
    20. #80
      Sep 2007
      York, Pa
      Name:  New rail drop in.jpg
Size:  236.1 KBName:  New frame front view.jpg
Size:  191.7 KBName:  New Frame boxing in.jpg
Size:  222.2 KBName:  New Frame boxing 2.jpg
      Justin Snow
