    Page 12 of 13 FirstFirst ... 2 7 8 9 10 11 12 13 LastLast
    Results 221 to 240 of 244
    1. #221
      Sep 2007
      York, Pa
      Great to see progress on this Justin.
      Did you attach the roll cage to the farm or just to the body?
      Quote Originally Posted by carguykeith View Post
      Cage looks nice! So what are those rear down bars bolted to? Are you making the whole cage bolt down and if so why?
      Basically, I had a hard time deciding if I wanted to put a cage in the car. I always had a very clean, original interior and I wasn't sure I wanted to disturb that, but I also wanted 6-point harnesses and the additional chassis stiffening. I decided to do the cage but make it easily removable If I (or eventually my son) ever decide we want it gone. It looks like it just bolts to the floor but I have standoffs under the floor that tie into the frame. Another benefit is I can still lift the body off the frame just have to unbolt the cage.
      Justin Snow
    2. #222
      Sep 2007
      York, Pa
      Don't worry the grade5 bolts are just temporary. I will order some nice ARP bolts eventually.
      Justin Snow
    3. #223
      Sep 2007
      York, Pa
      This shows how the cage ties in under the car. Im probably going to rework this crossmember to get it up closer the floor. This one was easy because it was just three straight pieces of tube but I think I should build one that kicks up toward the floor.
      Justin Snow
    4. #224
      Aug 2012
      Peoria, AZ
      Nice shocks!! You are going to love them. I'm happy to help you out when it comes time to dial them in.
      Can you show some pictures of how your main hoop attaches to the floor, and the frame stand offs? I'm picking my car up from the fab shop today after my roll bar install and I'm curious to see how my install varies from yours. You have done a great job so far on yours.
      Lance
    5. #225
      Sep 2007
      York, Pa
      This is how I did the main hoop. It was more of a PITA since I had to rework the floor to make it flat. Also had to make the lower plate threaded because I wont be able to access the bottom of this spot to put nuts on. There is a short standoff under the floor here just like in the trunk area.
      http://i1189.photobucket.com/albums/z429/GNon18s/floor%20patch.png[/IMG][/URL]
      Justin Snow
    6. #226
      Mar 2010
      Okinawa, Japan
      WOW! That's a lot of work to make it removable, I just built mine so I could raise the body up off the frame enough to weld it all easier and figured if it had to come off that would be enough room to to get the cage out if I ever needed to. Yours is a hell of lot more surgical though and should still pass tech if you wanted it to. Oh and I'd just go with some grade 8 bolts ARP would be overkill.
      Awesome build btw!
    7. #227
      Sep 2007
      York, Pa
      I agree lol ..but it didn't cost anything!! The labor doesn't bother me too much. It's some of the super expensive parts that drive me crazy.
      Justin Snow
    8. #228
      Aug 2012
      Peoria, AZ
      Thanks for the pics, awesome work.
      We don't have kids and have almost never had anyone ride in the back seat, so I took the easy way out with a permanent rear seat delete\4 point bar setup...but I can greatly appreciate the work you put into keeping your street car track safe. It isn't an easy task for sure.
      Lance
    9. #229
      Nov 2012
      Awesome ride you have going!
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
    10. #230
      Apr 2014
      Yes this is cool build with a cool car!
      Pat
    11. #231
      Sep 2007
      York, Pa
      Quote Originally Posted by 66larkgs View Post
      great build !! not to many of us buick guys and you are building one real nice GN. Your gaps look real good on the cage , but have you ever try the paper towel templet trick. use the inner part of the paper towel to make a templet and just slide it over your pipe and transfer over. I am a big jeep guy and it helps getting those gaps nice and tight. Great looking jeep and GN and look forward to seeing more progress
      Thanks for the tip! My paper towels had too much on the roll to waste but I found the cardboard from a TP roll. Works awesome, Its practically a slip-fit over 1-5/8" tube! (rebuilding my crossmember, curved for more clearance and stronger)
      Justin Snow
    12. #232
      Sep 2007
      York, Pa
      Quote Originally Posted by Zoomin View Post
      Quote Originally Posted by keepat View Post
      Pat
      Justin Snow
    13. #233
      Jun 2013
      Phoenix
      Justin,
      Nice. nice work!
      Would love to see pics of how you ended up mounting the LCA's to the frame and how you worked out the trunk hinge.
      Todd
    14. #234
      Feb 2015
      Subbed. Amazing work Justin. Thanks for posting on turbobuick.com too or I would have missed it.
    15. #235
      Sep 2007
      York, Pa
      Quote Originally Posted by GNon18s View Post
      I spent a full day building new lower control arm mount for the frame. Again, I just went off the stock design and just tried to beef them up a bit.Attachment 70477Attachment 70478
      This shows the lower control arm mounts I welded on the frame
      Justin Snow
    16. #236
      Great work Justin.
    17. #237
      Continues to be a great thread!
      Mike
      www.musclecardeals.com
    18. #238
      Aug 2015
      Madrid Iowa
      Anything new on this? Great looking car man. You do great work.
    19. #239
      Mar 2016
      I'm curious about your a/c delete plate. Can you tell me where you found the stainless button head bolts for you block off plate? Also what is the size of those bolts? I can't find those anywhere. Thanks for any help.
      William.
    20. #240
      Does it run?
      86 Buick GN, Stage 2 V6, Twin EFR Turbos
