      Dec 2012
      Single Adjustable Shocks: Rebound only vs Compression + Rebound
      Regarding single adjustable shocks: (given: the single adjustable is less versatile than a double adjustable)
      On the surface it would seem that the single adjustable with simultaneous rebound + compression
      adjustment would provide more performance advantage than the rebound only single adjustable when
      set to similar rebound.
      Thoughts?
      1977 400 TA, 9.5:1 CR 351hp 411LbFt
      700R4 2200rpm, 3.42 Eaton posi 10bolt, PS, PB, PL, PW, AC, Cruise
      [email protected] 2.18 60ft on 255 60 R15 street radials, mpg: 21.5 hiway, 15.2 city
      Dec 2009
      El Dorado Hills
      Problem I've run into with single adjustable compression/rebound adjustment is the shock bouncing under high load. Could be the brand of shock I'm using......dont know for sure but I recommend double adjustables.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
