    Results 1 to 12 of 12
      Dec 2012
      Single Adjustable Shocks: Rebound only vs Compression + Rebound
      Regarding two of ridetech's single adjustable shocks: (given: the single adjustable is less versatile than a double adjustable)
      ridetech Smooth Body Shock - HQ Series (manual adjust rebound only)
      RideTech Universal stand alone Select Series (electronically switchable rebound + compression)
      On the surface it would seem that the select series with simultaneous rebound + compression
      adjustment would provide more performance advantage than the rebound only HQ series when
      set to similar rebound.
      Thoughts?
      1977 400 TA, 9.5:1 CR 351hp 411LbFt
      700R4 2200rpm, 3.42 Eaton posi 10bolt, PS, PB, PL, PW, AC, Cruise
      [email protected] 2.18 60ft on 255 60 R15 street radials, mpg: 21.5 hiway, 15.2 city
