    Page 8 of 46 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 18 ... LastLast
    Results 141 to 160 of 902
    1. #141
      May 2011
      Brisbane, Australia
      Country Flag: Australia
      Don't lose heart. It is an awesome project. Making something as unique as this takes time but will be worth it.
      1966 Plymouth Fury III
    2. #142
      Oct 2007
      Camas, WA
      1968 Volvo project Pure Volvocity
      I had a conversation with my body guy last week about wanting to take the car to another shop so it will progress at a faster pace. He asked for anther chance and has really picked up the pace. He finished the hood and has the new buckets for the tail lights built and ready to mold in. I am really pleased with the progress he is making now.
    3. #143
      McKinney, TX
      What tail lights are those?
      89 Mustang "Box Wine"
    4. #144
      Oct 2007
      Camas, WA
      They are from the first generation Lotus Eclipse. Aftermarket LED versions I picked up from http://www.eliseparts.com/.
    5. #145
      McKinney, TX
      These?
      http://www.eliseparts.com/products/s...rear-lamps-s1/
    6. #146
      Oct 2007
      Camas, WA
      Those are the ones. The S2 lights have a larger diameter.
      Are you thinking about them for a project or curious?
    7. #147
      McKinney, TX
      Sort of both, I'm not sure they would "work" on a Mustang though. And they're a little pricey
    8. #148
      Oct 2007
      Camas, WA
      The light turned out terrific! I couldn't be more pleased with the results. It is almost identical to the VOX rendering except the inside light is slightly smaller on the rendering.
    9. #149
      Oct 2007
      Camas, WA
      Here is a picture of the rendering.
    10. #150
      May 2011
      Brisbane, Australia
      Looks better than the rendering!
    11. #151
      Feb 2013
      Quote Originally Posted by Godbolt View Post
      Agreed!
    12. #152
      Oct 2007
      Camas, WA
      I have been making progress on the suspension modifications. I changed the springs to PAC Racing Springs but 1" shorter to allow for more ride height adjustment. The orange color isn't my favorite but they will work.
      I changed out my lower control arms for a newer version that has additional reinforcements. They were provided to my by Mad Volvo who too over the production and sales for Sweedish Ops. They are really nice and the finish was a perfect match. ?
      I also installed the front splined away bar. That took a little planning since the sway bar bushing has quite a bit larger spacing between the bolts. I mounted the bushing to a piece of flat stock with a nut welded to the cack side of the steel where the back hole is attached. The front hole is mounted where the factory mount is bolted to. For the back mounting point I used an existing factory hole and installed a Rivnut.. This way I can go back to a factory bar style setup it if I want.
      The arms for the sway bar was kind of fun. I ended up buying some pretty nice end links from Total Control Products that utilize heim joints and are rebuildable. The have a stud that comes off at a 90* angle that attaches to the arms. I had to cut the arms down and then tap them to accept the studs. Looks really clean and should work great. I still need to shorten or buy shorter bolts for the suspension crossmember mount. It looks like they may rub on the arm if I don't.
      I also moved the upper link bar mounting pint to the inside of the frame rail. I picked up some brackets from Mad Volvo Performance. I had to cut some of the floor under the rear seat and still need to make that look pretty. I also picked up a revised upper shock bar that adjusts the shocks to a slightly different position and is less bulky than the original Sweedish Ops design.
      I still need to mount the rear end back in the car but it is getting close to done with the suspension for now. I do plan on getting rid of the QA1 shocks for a set of JRI's. I am not sure if I will go with triple adjustable a or stick to singles. One last item, My wider wheels should be done this week. Once I get them mounted I will give the car back to the body shop so they can work their magic.
    13. #153
      Oct 2007
      Camas, WA
      Here are a couple pictures of the rear suspension bar and brackets installed. And welded in place. The entire piece is removable for service if needed. Now it needs a little paint!
      Darreld
      Sent from my iPhone using Tapatalk
    14. #154
      Mar 2013
      Southern Idaho
      I think your 'equal' sized tail lights look much better than the rendering! They remind me of a Ferrari. ...or a Lotus. lol
    15. #155
      Apr 2010
      DC
      Great project and I can't wait to see the outcome. Those taillights are really nice and for a moment there I was wondering what they'd look like on my Mustang...
    16. #156
      Feb 2015
      nice done so far
    17. #157
      Sep 2015
      SW KS
      Looking good!
    18. #158
      Oct 2008
      Great project. I have been gathering parts to build a 70 MGB. Just too many projects right now. Love the taillights.
    19. #159
      Quote Originally Posted by gcallahan View Post
      Be sure to cross post on the MGExperience and British V8 websites, please. Not enough pro-touring MG's- i'm working on an MGC myself (Keeping the green monster MGC six cylinder in it (EFI thru 3 SU carb throttle bodies)), but big brakes, Kore 3 hubs, quick steering, 4 link, etc.
      Vert- Sorry for the thread hijack, the tail lights are... hell, the whole car is bitchin'
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
    20. #160
      Oct 2007
      Camas, WA
      Thanks guys.
      I got the new wheels in and tires mounted. The prancing moose center caps set them off nicely.
      When I was welding the brackets on the housing to move the link bars to the inside I had a little problem. I must have warped them and now the housing is leaking gear oil. I think I am just going to get a new housing and call this a learning experience. A 9" is now on the way as well as a new Dutchman 3rd member with truetrac.
