Results 21 to 23 of 23
Thread: Mil spec wire crimpers?
08-17-2005 #21
Here's a good link showing connectors: http://www.jrhelec.com/index.shtml Here is a similar crimper and postioners (notice how many) that I'm talking about: http://www.astrotool.com/Products/mi...crimp_tool.htm
Edit for: even there ther is a MIL spec or standard, that standard is materials, dimension and size. The different companies use different part numbers. And most of the time they are not intermixable. The part number is actually made up by the type of connector so if you can go to that manufacturers web page you can decode the part number to determine the connector type, size, number and size of pins, angle, etc. Unfortunately, this will not be a easy task (to use and wire one's car with these plugs). I think the result will be well worth the effort but it's going to take a lot of effort).Brian
'68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
