      Nov 2010
      Package Tray Replacement... Marquez Design
      Hey guys I am an audio freak.. and am thinking about replacing my stock package tray because it is rattling and causing some weird sounds back there when I crank p the volume. I am thinking about replacing it with a fiber glass package tray from marquez design
      Has anybody here installed one and chime in if it elminated the weird noises.. or would it be best to remove the old one put some dynomat on there and put on the a new one from marquez design.
      I have mm polk audio 6x9 in the back and some 6.5 in the front with a 10" jl audio w7 in the back that i am about to get a custom fiberglass box built for it. Thanks for all the advice...
      P.S I am running about 900 watts rms total in the system and the entire flow is dynomate'd but nothing is done in the rear.
      Thanks for any help
      68 Camaro RS twin turbo
      Slow Lifted Jeep No TURBO :(
      Randal F
      Jun 2009
      Cape Coral, FL
      I'm just putting my set together and testing it out before the car goes to paint, the only thing I have not dynamated was the package tray itself, I currently have a 12 firing down directly beneath it. I haven't heard a single rattle and I have cranked it the point the garage doors were rattling. It could very well be the clips holding the rear widow trim, I would have someone press on those while you have the music going to determine if that may be the source. But I could be dead wrong.
      Mar 2004
      Mid-Michigan
      I would find the source of the rattles first like Chris mentioned. It sure would be a PIA to do all that work and find it is something simple like a clip or loose screw.
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Nov 2010
      Thanks Guys.. I will check that.. But it seems the wood is a little rotted... I think that could be part of the problem, and will check the screws as well!! But I am going fiberglass anyway!! It will be the self proclaimed christmas present for the 68
      Randal F
