    Results 1 to 15 of 15
      Jul 2012
      Auburn Hills, MI
      Trouble getting good pedal
      I have a 78 nova that I can't get a good pedal on no matter what I do. I replace the whole brake system with all new components when I redid the front end of the car. All hard lines were replaced with stainless, all flex hoses were replaced with new quality parts, new stock replacement front calipers, and I replaced the rear drums with the disc brake setup from right stuff detailing. It is the kit with the integral parking brake style calipers. Master cylinder I started using was a 1 1/8" unit for a 70s corvette with 4wheel disc brakes. Proportioning valve was a unit off of eBay for disc-disc. I must have put 4 gallons of fluid through the system, no bubbles present at any corner, and when I would touch the pedal, it would go right to the floor with no resistance at all. (Master was bench bled until no bubbles were seen in the reservoir ports and the piston could not be compressed.) I would go back to bleed the four corners and get one or two air bubbles then solid fluid, but the pedal always went right to the floor. Recently I switched to a 1" bore unit from a blazer/s10 with 4wheel discs, and a new proportioning valve from right stuff. The pedal now feels better - there is slight resistance in the pedal and it doesn't go to the floor, but it still does not feel solid like it should.
      I have called right stuff several times followed their tips and still can't get a good pedal. The bleed screws are all pointed up and the parking brake is adjusted so that the arm on the caliper only moves about 3/8 of an inch before it locks onto the rotor. I did initially have a leak at the LR caliper and the hard line that goes from front to back where it meets the flex hose to go down to the axle, but those have since been fixed. I have tried several different bleeding methods - pump and hold, one man bleeder, motive products power bleeder, open bleed screw push down pedal close bleed screw before pedal gets to end of stroke, all with the same results.
      This last time i bled the brakes, it looked like the fluid coming out of the front calipers was aerated. I am about ready to give up on this system and just bite the bullet and purchase the larger brakes I have on my long term list. The brakes I am looking at are the C5 front kit with spindles, hubs, rotors, calipers and braided flex hose from CPP and LS1 rears. Any help or pointers to make my current setup work would be appreciated.
      Oregon
      It's odd that changing from a 1.125" bore MC to a 1" bore unit seemed to help your situation since reducing the bore size and thus the amount of volume supplied by the MC to the calipers per inch of pedal stroke would typically have the opposite effect in a system with air, and it definitely sounds like you either have air in the system or misadjustated rear calipers. I'm not sure I can make an suggestions beyond those already stated since your actions and the resulting effect don't seem to jive. That said, have you isolated the front and rear circuits and tested each individually? That's not to say that you don't have issues front and rear, but it's typically easier to work on one end of the car at a time as it narrows down the variables substantially. I would start with plugging the MC port to the rear brakes and then sorting out the front first since there are fewer things to go wrong with simple non-parking brake calipers. Once you get a good pedal up front, then reconnect the rears and give them a go. There aren't that many components in a brake system, so with a little effort you should be able to track down and isolate whatever the issue is.
      Tobin
      KORE3
      It's what I does.
      Jul 2012
      Auburn Hills, MI
      Yeah, I also thought it was weird that a smaller bore yielded the results it did. I will try plugging the rear system at the master cylinder see if I can isolate the problem. Thanks for the tip Tobin, I was hoping I would get a response from you.
      May 2002
      Northern California
      Quote Originally Posted by Nova1978 View Post
      I have seen fittings leak especially stainless fittings, not enough leave a puddle or droplets but enough to be sucking air. I like to use baby powder to find tiny leaks.
      Do you have a booster or is it manual brakes? Could it be a pedal ratio problem? If you have a booster, does it have an adjustible push rod?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2012
      Auburn Hills, MI
      Brakes are power, I am using the factory power brake pedal, a factory replacement Delco-Moraine brake booster with non-adjustable pushrod. I was thinking that it could be possible one or more of the fittings is not making a good seal. I did the trick with all of the fittings where you seat it 7 ish times by tightening and loosening the fitting, but it could be possible that there is one or more that still have a slight leak.
      Oct 2012
      Casey,il
      Are you getting enough vacuum to the booster?
      Jul 2012
      Auburn Hills, MI
      Yes, the power assist works very well in fact. Before I changed master cylinders and the rear brakes, I was using this same booster and it worked well. With the car off I can't get a good pedal, and it is worse when you start it up. I replaced the booster before because the original unit quit working. With this unit you could unhook it and the brakes were significantly harder to use and when hooked up the brakes felt like they do in all of the other cars I have driven with power brakes.
      Jul 2012
      Auburn Hills, MI
      Ok, so today I plugged off the port on the master cylinder that feeds the rear brakes, and hooked up my power bleeder. Went through the normal process of checking for leaks, and once the system was air-tight, I proceeded with bleeding the front brakes. I pressurized the system to 10psi, and started with the passenger side - no air bubbles at all, and I made sure to bleed the system for a while. Moved on to the driver's side and there was a fair amount of bubbles present so I bled and bled that caliper until I got solid fluid with no air bubbles. De-pressurized the system, and touched the brake pedal - I can only move the pedal about 50% of the stroke (pushing with my foot, not my hand) before it comes up really tight. There is about 2.5-3 inches left for the pedal to move before it would hit the floor. The pedal feels better, but there still may be some air present because I found several leaks at some connections while I was cleaning up. Now on to the back brakes..... again.
      Santa Clara, CA
      Sounds like some progress, though! Good luck.
      Steve
      Jul 2012
      Auburn Hills, MI
      Found a couple leaks at the back end by pressing and holding the pedal down for a minute or so, and got them fixed. Rebled the entire system, couldn't get any air bubbles from any of the calipers, and I put about a whole quart through the system. Tried the pedal and it feels slightly better, but it still won't "pump up hard" to the point where you can't push it down for some reason. It will however clamp onto the rotors pretty good. With a wheel on, and pushing the pedal down about 2-3 inches, the wheel can no longer be turned. When I push on the pedal, it has moderate resistance, and springs back up pretty quickly if you let your foot slide off of it, but still isn't what I would like it to be. Maybe this is all the better it will be with the 1" bore master cylinder.
      May 2002
      Northern California
      Are you still using a 1" MC? Going smaller will make it worst. Stay or go back to the 1.120
      Lets back up a bit with a few more questions.
      Did you change from a manual master to power or is this a power brake car?
      Make sure you have the proper rod and it is not depressing the master piston prematurely.
      Are these new masters? If you are using a used master it is possible that the seals a worn and leaking into itself.
      I still think you may have a pedal to booster angle issue or air in the system.
      Jul 2012
      Auburn Hills, MI
      The nova has been in the family since it had 10,000 miles on it. The first time anything in the brake system was touched was in 2008 when I replaced the factory power brake booster with a quality unit which has been working ever since. The brake pedal is the factory pedal for power brake applications with the hole in the factory location. Brakes worked fine with the stock type stuff - disc/drum. I could lock up the front right tire with that setup. All master cylinders that I bought are new units not reman. I recently bought the 1" bore s10 unit and the 1.125" corvette unit. The size of the rod that is on the booster was measured for diameter, distance it sticks out and the depth that it would reach into the master cylinders. All measurements indicate that there would not be any issues. The push rod on the booster is non adjustable. I'm thinking that I am at the limit of the 1" bore master. I don't think it is pushing enough fluid to make the pads contact the rotors until near the end of pedal travel. With a larger bore master, it would push a larger volume of fluid, making the pads contact the rotors sooner and allowing pressure to build up higher in the pedal stroke, which should theoretically yield a "firmer" pedal higher in the pedal stroke.
      It is very possible though that I may have air trapped in the system still.
      Southern Indiana
      I am curious, have you put any pressure check valves in the system? For disc conversions I found the 2 psi units usually helped the pedal feel on a conversion. They also make 10psi units I had a guy using 1/4 in lines to rears and we had a heck of a time, we installed 10 psi units and fixed his issue. Turned out the calipers he used in back were using a low drag style seal that helped pull piston back few thousandth more and the check valves helped greatly.
      From what I have seen going down in master cylinder area made the system build pressure faster but also makes it a harder pedal feel, ie you need to put more effort into it.
      I also helped a guy using front caliper in back, man that car was POS to stop. I finally got him to swap out those for S10 rear disc, tada much better balance. And he did same thing to adjust pedal feel, swapped master cylinders till he got it to feel right. His car wound up with 7/8 bore. Stops great now. One thing I am still looking for was the old equation I got from a GM engineer, it gave the area ration between master cylinder piston and master cyl. THEN you took that and put it into equation for torque force capabilities of brakes to decide on brakes. He even gave me whole list of different GM calipers and rotors specs. Was supposed to help keep pressures right, then play with pad compunds to fine tune. Info they used for street class racing setup. Hope I haven lost it, would be cool to post up.
      Lee Abel
      AFTERMARKET PERFORMANCE
      Jul 2012
      Auburn Hills, MI
      No, I haven't put any check valves in the system. I have read about them and saw where people used them for a drum rear setup, but I can see where it may benefit a disc setup. I have noticed that with my power bleeder pressurized to 10 psi, I can still pull the rear calipers off the rotors and the piston doesn't come out of the bore. Is that normal?
      As for the equation, it would be a fairly straight forward equation to derive because in the end you are comparing moments of the wheels/tires to the moments of the rotors. If the moments of the tires is more than the rotors, you will not be able to lock up the tires. In order to use this equation, you would need to know F/R weight bias, normal force on the tires friction coefficients, etc. Then again, I am a mechanical engineer and work in the auto industry, so I live for this type of stuff.....
      Jun 2006
      Katy,TX
      Lee if you find that chart it would be neat to see.
      1965 GTO project car
      2004 Pulse Red GTO
