Results 1 to 11 of 11
Thread: Heat Sheild Help
08-07-2005 #1
New to Pro-Touring
- May 2005
- Orlando, FL
- 75
Heat Sheild Help
I think I am overheating my power steering box. When I first start up in the morning the power steering is great, no problems at all. After a bit of driving I hit dead spots. If I park it for an hour or so it is fine again. I was looking at my Hooker super comp long tubes and my #1 header runs about 1/8" from the steering box and it makes it VERY hot. #3 & #5 run somewhat close too.
So I am thinking that the PS fluid may be boiling or becoming so thin that I get dead spots. The engine is supercharged so my headers get quite hot. I thought about wrapping the header that runs closest to the box but would that do? I dont like how the header wrap looks but it would only be a small area of the header.
Any ideas.
This is on a 69 camaro.
08-07-2005 #2
- Aug 2004
- England
- 1,042
Can you put a small flat dent in the hedders by the steering box to give a bit more space then make a stainless cover to go between and header and the box but on the side nearest the box put some header wrap against the cover and box, the cover then should cover also most of the dents in the hedders . I only say stainless as it might reflect some of the heat, you could poss use alloy.
paul67
08-07-2005 #3Have you installed a power steering fluid cooler? If yes then I would build a heat shield like Paul suggested. I would use aluminum. You could even polish it to make it look nice. Stainless would not work as well to get rid of the heat. Unfortunately, 1/8" space is not much to work with at all. Mabey you could attach the heat reflective material to one side of the shield and use 3m super silicone sealant and glue it one side of the shield. The super silicone can easily withstand header heat.
08-07-2005 #4
New to Pro-Touring
- May 2005
- Orlando, FL
- 75
Havent tried PS cooler, I was hoping there would be another way out. Might have to end up putting a cooler on it.
The hooker supercomp LT's are common on 69's, I was wondering what others have done to overcome the heat.
08-08-2005 #5Did you read the rest of what I said besides the steering cooler? I mentioned what you could do with a heat shield.
08-08-2005 #6
New to Pro-Touring
- May 2005
- Orlando, FL
- 75
I saw that part. I like the idea of putting material on the heat shield, like taking a spark plug sock and cutting down one side to make it flat and attatch to one side of the heat shield. I was hoping that someone made a shield for what would seem to be a common problem. I know the turbo guys use heat shields.
I also wasnt 100% convinced that the steering problem is coming from the heat but it seems likely to me. What do you think?
09-13-2005 #7
Full Blown G-Machiner
- Sep 2004
- PA.
- 935
