    Results 1 to 13 of 13
    Thread: Lsx-454
      Jul 2011
      Stafford Va
      Lsx-454
      Well my deal for a 418 with a certain vender fell through so I am searching again for a power plant. I am still leaning twds the LS3/ 418 or 427 600hp motor but I have thrown the LSX 454 back into my list of options. My build is below and would like to get some of the feedback from those that have the LSX 454. Thanks Kevin
      https://www.pro-touring.com/showthre...-replica-build
      Jan 2012
      Country Flag: Cambodia
      Good to see more Corvettes on this website. I am almost finished with a custom chassis C2 Coupe and have 68 Coupe in the planning stages. For the 68, I am either going with an LSX 454 with Holley Hi Ram, or a Dart all aluminum BBC 582 with multiport efi. The LSX has low 700hp and the 582 is high 700s. It still astounds me that the aluminum 582 costs less than the LSX.
      Jul 2011
      Stafford Va
      I was looking at the 620hp LSX, would not know what to do with 700hp
      Jan 2012
      LSX 454 with 700hp are aftermarket crate engines. Golen Engine, TSP, and MAST all have an NA LSX, in that power range but cost more money.
      Jul 2011
      Stafford Va
      Understand , how ever I was wondering who was building your motor for a lot less. The other thing I am looking at is the warranty since I will need to have it in the frame to set it up with the trans and build the headers and finish the body work so it will be just sitting for a while before I even turn the key for the first time. 6 months will be a good guess which does not leave much for a warranty if its only one year
      Sep 2002
      So. Cal
      Quote Originally Posted by vstol View Post
      I'm very happy with my TSP LQ9 370 short block. Great price, great service and so far great performance with my small twin turbos.
      Before the LQ9 build, I looked into the LS7, RHS and LSX engines. My goal was +700 crank hp and found $17-20k+ was the norm...Ouch
      Since I had the twin turbos already, it made much more sense for me to go with the LQ9. Good thing I wasn't highly concerned about weight. If I had been, I would be biting the $20k+ aluminum bullet.
      If 600hp and lower cost is you goal, the LQ9 or LS3 is a good choice. $13-14k complete.
      Not sure if anyone will warranty 6 mo let alone 1 year out? Get yourself a junkyard block for mock-up if you are worried about it.
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Hildebran, NC
      check this video out if you want to hear one being abused!!
      http://www.youtube.com/watch?v=MnSd322vj0Y
      http://www.youtube.com/watch?v=U_GAj...ture=fvwp&NR=1
      search you tube for Tim Cameron
      Jul 2011
      Stafford Va
      thanks thats quit a buggy
      Santa Clara, CA
      Kevin, have you made your decision yet? What's your current thinking, given the feedback that you've received here?
      Steve
      Jul 2011
      Stafford Va
      Steve, not sure and since I have not picked up my corvette up I have sometime to decide. I believe the LSX 454 under my hood is a great way to go and not sure if I would go FI or carb. Then again 200 lbs lighter for the same HP and torgue is also tempting which is the original path I was taking.
      Kevin
      Jul 2011
      Stafford Va
      anyone else that has the LSX 454/620hp
      Jan 2009
      I have an LS7 based 454, which isn't exactly the same thing, I know. The block is different, but the overall idea is the same. It makes a lot of torque. I mean a lot of torque, and is an absolute blast to drive. If you aren't worried about weight it would probably be the most fun option!
      Jul 2011
      Stafford Va
      I believe the LSX 454 is the way to go for my project and I like the 2 yr warranty. I am still wrestling with going with a carb, more for the vintage look but FI is sweet.
