    Page 22 of 29 FirstFirst ... 12 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
    Results 421 to 440 of 578
    Thread: 69 GTO Build
    1. #421
      Merritt Island,FL
      Car looks great man ! Nice work !
      Check out my web site.
    2. #422
      Those are some good parts going in the motor. Paint looks great!
    3. #423
      Jun 2012
      N. Shore, Ma
      Cutting trunk
      Thanks Brian, Your GTO is getting there too, let me know how it goes when you get to matching the front top of the quarters. Look at my post #320
      Wayne the paint is not perfect and the bugs that are stuck in it will be there a while, but thanks.
      Starting the Fuel Cell install.
      It is strange that I cared after all the other metal work I have done to the car, but it was a sad moment cutting out the nice original trunk floor that survived all those years without any rust.
Size:  40.4 KBName:  IMG_2620.jpg
      Eric
      Building 1969 GTO - Roadster Shop chassis, LQ9 w LS3 heads and rebuild parts from TSP, Bowler prepped Magnum T56 6 spd, 3 Link Strange 9" w Speedway Floater Hubs, Wilwood 14" F - 13" R brakes, 275.18 - 345.19
      https://www.pro-touring.com/threads/94970-69-GTO-Build
    4. #424
      Jun 2012
      N. Shore, Ma
      Fuel Cell Work
      Few shots of the Fuel Cell install in progress.
      Welded the 16 Gage steel box that I made into the trunk, then built the square tube cage.
Size:  48.1 KBName:  IMG_2731.jpg
      I have never trusted rivnuts for heavy duty jobs so I welded some 3/8-24 nuts under the top tube for the two top cross bars.
Size:  43.1 KBName:  IMG_2735.jpg
      Need to remove and finish weld everything now.
      Eric
    5. #425
      Jun 2012
      N. Shore, Ma
      Fuel Cell mount done
      Welded in, just need to paint now.
      Now I might need some help from everyone picking components for running the fuel line next.
      Bought a roll of 3/8" NiCopp that I was thinking on covering with a high temp polyester sleeve to insulate and protect.
      Then I plan to run -8 Aeroquip PTFE SS braided from cell to 10Micron Filter (mounted inside frame above axle)
      Hardline mounted to top inside of passenger side chassis with cushion clamps, stopping at fire wall next to inner body mount
      More -8 Aeroquip to Fuel Rails,
      Y block to Regulator
      Then return line using the same 3/8" NiCopp but with -6 hose Thanks in advance for any thoughts
      http://hosewarehouse.com/Hydraulic/H...7-8?mfp=search[S-8TW]
      http://www.mcmaster.com/#9196k13/=1054erc
      Eric
    6. #426
      Jun 2012
      N. Shore, Ma
      Fuel Line Schematic
      Looking for feedback on my proposed fuel line setup,
      -8 feed line using the Aeroquip PTFE into 3/8 NiCopp hardline on chassis
      (most of my friends with serious drag cars run -10 and I believe that -6 would work fine but I just don't want to listen to their comments)
      -6 return line from the motor
      Plan on going with an in tank pump either Bosch 0 580 254 044 or Walbro 255
      Would love to hear thoughts on favorite brands and good sources from those that have more experience than me
      I have been reading lots of posts on the forum and appreciate all the great tips and info that is out there!
      Cool link if you don't want to build your own lines.
      http://hosemachine.com/?load=true&ma...=&oal=&phase=0
      Name:  FUEL LINE .jpg
      Eric
    7. #427
      Jun 2012
      N. Shore, Ma
      More Paint
      Finished painting SEM Rust Shield in trunk and bottom of car, my last coat I didn't use as much reducer and I sprayed from further away so that it would go on with a texture.
      Wanted some contrast between gloss black on chassis. Getting ready to remove suspension so I can spray chassis again to fix some issues I had last time, plus the guys at the frame shop were not very nice to it.
Size:  55.2 KBName:  DSC02729.jpg
Size:  32.9 KBName:  DSC02731.jpg
      Made some aluminum trunk firewall panels, still need to use the bead roller on the big ones.
Size:  76.5 KBName:  IMG_2815.jpg
      Eric
    8. #428
      Waterloo, Ia
      Awesome! Keep plugging away!
      -Nick
      -1967 GTO I drive and race
      -Build threads:
    9. #429
      Jun 2012
      N. Shore, Ma
      Chassis Paint
      Thanks Nick!
      Happy New Year!
      So nice to have the hoist to get the frame on the rotisserie.
      Sanded entire frame again with 320, I'm getting good at this.
Size:  43.2 KBName:  DSC02791.jpg
      Used more slow reducer with the SEM Rust Shield, helped it lay out smoother this time.
Size:  58.9 KBName:  DSC02815.jpg
      Suspension all ready to go, all the bare aluminum and gold zinc bolts polished up and protected with Shark Hyde. Everything had started to corrode from the ride on the flatbed last winter, the salt spray on the highway must have got on everything.
Size:  87.6 KBName:  DSC02838.jpg
      All the aluminum and hardware on the rear end looks great, I treated it with the Shark Hyde last year before it went out to the frame shop and its holding up nice.
Size:  71.6 KBName:  DSC02845.jpg
      http://www.sharkhide.com/mpinfo.html
      Eric
    10. #430
      Aug 2012
      San Diego
      Eric,
      Awesome progress! For your supply line question... have you thought about 1/2" aluminum tubing? As compared to stainless steel, it's super bendable. I have 3/8" stainless, and it was a pain in the ass to bend and especially flaring the ends. Of course, after I was done, a new GTO friend of mine showed me what he did... 1/2" aluminum is going on the next car.
      Keep it up!
      Mike
    11. #431
      Jun 2012
      N. Shore, Ma
      Fuel lines
      Hi Mike thanks! Yeah I think I am just going to run -6 feed and return along with the 3/8" Nicopp hardline for both since the majority of people say that it will work fine.
      If I ever want to go crazy with more power I can upgrade the lines later.
      Not much to report, been busy working. Started gathering hardware and materials, hope to get lines finished soon.
      Eric
    12. #432
      Jun 2012
      N. Shore, Ma
      Fuel Lines
      Sorry for the lack of updates, I have been trying to get things done with a broken thumb and having a tough time. I know its not the best excuse but it really is hard to stay productive!
      Was able to finish the brake and fuel lines finally. Just need to measure up and order front and rear caliper hoses and axle drop hose.
      http://www.kore3.com/products.php?cat=20
Size:  25.8 KBName:  DSC02920.jpg
Size:  49.2 KBName:  DSC02931.jpg
      Eric
    13. #433
      Dec 2010
      Charlestown NH
      oh wow
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    14. #434
      Jun 2012
      N. Shore, Ma
      Kore3 lines
      Luckily the thumb doesn't stop me from ordering parts! Called the Roadster Shop to double check my measurements on Caliper hose, I figure they have done it a few more times than I have. Very cool and supportive guys at the Roadster Shop, its nice to have them in my corner cheering me on, sometimes it feels like the world is against you on these long builds.
      Then based on everyones good experience with the guys at Kore3 I got in touch with Tobin. Placed the order then had the lines in my hands a couple days later. Nice guys and nice parts too!
Size:  59.4 KBName:  IMG_3072.jpg
      Eric
    15. #435
      Jun 2012
      N. Shore, Ma
      LQ9 assembly
      Making progress on the engine rebuild, cleaned and measured clearances on crank, everything looked good so crank is in.
      Was checking out the new Mast oil pan, but I might be able to run a GM F-body oil pan with my 4" setback, would give me good ground clearance since they are the shallowest I have found at 5.63" (before going custom)
      http://www.mastmotorsports.com/view.php?id=160&c=49&s=7
      Just picked up some new Engine Pro trunnion bushings, they just came out with them and the distributor said they are not in the catalogues yet. I ordered them through my local machine shop. I like the idea of keeping little needle bearings out of the engine.
      The trunnion kit is part # 07-13702-16
      http://www.stevemorrisengines.com/st...d-service.html
      https://www.youtube.com/watch?v=dn898OCAAls
      Not able to upload picts, says I'm over my 18MB limit.
      Eric
    16. #436
      Jun 2012
      N. Shore, Ma
      Engine work
      More progress on the engine in between work.
      Got the file to fit rings done, new custom grind Texas Speed cam is in and got the rods back from machinist.
      Had them hone the rods and fit the new wrist pins with a .0003 to .0005" slip fit between the rod bushing and wrist pin.
Size:  37.2 KBName:  DSC02944.jpg
Size:  38.6 KBName:  IMG_3137.jpg
      Trunnion kit
      Eric
    17. #437
      Jul 2011
      Prescott, AZ
      Lookin good! We can't wait to see the engine completely assembled again.
    18. #438
      Jun 2012
      N. Shore, Ma
      Texas Speed Cam
      Quote Originally Posted by Centerforce View Post
      Thanks! Hey I'm in the market for a flywheel and clutch setup, any spring cleaning half price deals?!
      Slowly getting there, forgot to post new Texas Speed cam specs.
      Eric
    19. #439
      Jul 2011
      Prescott, AZ
      Quote Originally Posted by ekmxryda View Post
      What power range are you expecting with the new build?
    20. #440
      Eric wow, looking good! I'm thinking of one of those trunion kits too, it looks like anice set up.
    Tags for this Thread
