    Results 1 to 12 of 12
      Jun 2010
      Deployed
      Stuck! Custom Cooling Hose
      Ok, I thought I had this problem solved. I was going to buy a Cool Flex radiator Hose, but the company is giving me "parts awaiting" powder coating now for a few weeks now.
      I work in fabircation, I know it does take that long.....
      So I think I'm going to call BS and cancel my order.
      I need to know what other option I have to get custom bent hose. I have an LS1 with the radiator out-let on the driver side. The LS1 OEM hose will not work because my cold air intake is in the way. Thanks,
      1970 Camaro/DSE build
      Midwest
      Straight rubber hose ends, cut & weld some U bends to make what you need!
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      san diego
      I like going to autozone, finding some hose with the correct bends and adding one splice with stainless tubing and safety wire some clamps.
      Aug 2008
      jacksonville,fl
      After dropping my radiator mounting 2" to do my custom engine bay cover, I got a bathroom grab handle from home depot since it's 1.5" stainless .Used parts of it between my existing hoses. Sanded & polished so no one would ever guess what they started out as.
      Mar 2004
      Mid-Michigan
      Quote Originally Posted by jlcustomz View Post
      That's exactly what I'll be doing as soon as I get the radiator installation done. I would like to find one in 1 3/4" for the bottom line...
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Jun 2010
      Deployed
      Quote Originally Posted by astroracer View Post
      Mark
      I do have limitations...I can't weld or cut anything thick and heavy. Is there custom hose kits out there?
      Aug 2008
      jacksonville,fl
      You should be able to find stainless pipe with bends& cut what you can use from it. The rest can be from 1 or 2 hoses.
      Jul 2009
      New Jersey
      As others have suggested get it bent up powdercoated and use rubber ends. Looks awesome. Or weld an fittings.
      RJ Cilurso
      67 Camaro with a few things bolted to it
      12 Camaro with a few things bolted to it
      50 Chevy 5 window p/u with a few things unbolted
      USAF
      Dec 2010
      St Louis
      Can you solder? I had some odd angles to get my radiator connected to the LSx in my 68 corvette. I used copper plumbing with 90, 45, etc degree fittings at each end, painted them black. Also allows for size adapter if needed. Picked everything up at Sears hardware.
      Mar 2010
      Got any custom exhaust shops near you? Have them bend you up something like your mockup and use rubber ends
      Aug 2001
      Connecticut
      Speedway has the bends and sections needed to fabricate your own, either welding or using silicone couplers.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Jun 2010
      Deployed
      Quote Originally Posted by 68sixspeed View Post
      I saw that, thought it was a little too much $$ for what it was. I ended up spending $50 on a Summit SS flexible Hose. Hopefully it works out.
      I called Cool Flex today and told me they expect news at the end of next week....I canceled my order.
      I have a feeling he collects orders and send in mass quanties to save $$. I don't blame him, but I'm sick of waiting months for parts I need now.
