      Jerking on Deceleration
      Ran into a problem that I need help diagnosing. Took my car out for a spin yesterday and noticed that when I get on the gas in normal or spirited driving it is fine but when I lay off the gas the car starts to jerk back and forth almost like the car is in too low of a gear. When I try to put the car in a different gear and the RPMS climb on the gas it is fine but as soon as I get off the gas and the rpms fall to about 2200 I get the jerking motion again. I have a 383 motor with a camaro 6 speed in it. Brand new driveshaft with new ujoints and completely new MOSER 9 inch rear with trutrac and 3.73 gears. The pinion angle has been set up by a shop that knows what they are doing. I dont know how old the clutch is but it is hydraulic and shifts very smooth with no chatter at all. I have heard everything from motor mounts, to tranny mounts, to u joints to pinion angle, to excessive play in the rear end setup! I am praying that the rear is not the culprit since it is all brand new from Moser and I have heard nightmare stories about them when it comes to fixing or standing behind their products..
      Just looking for the best way to go about diagnosing this problem so I dont run around in circles with it. Any help would be greatly appreciated.. I know it is not a fuel issue. It is very apparent in first gear going around a parking lot. So bad I have to put it in gear and immediately put my foot on the clutch to coast around with the throttle off.
      Mark
      TOOFUN
      Jun 2005
      Did you ever solve this problem?
      Anthony
      http://www.cardomain.com/ride/674663
      '71 Datsun 510, 2jz-gte (Supra TT) engine
      http://instagram.com/supra510
