      Oct 2012
      Waltham, MA
      Holley Hi-Ram intake
      Has anyone used or checked out Holley's new intake?
      What I am needing to know is if the upper section can be reversed, so the TB location is in the rear with the 102mm upper or will I need to get the parts to build this myself.
      As I have decide to go with twin turbos instead of Kenne-Bell SC set-up. My problem is the engine is in a mid-engine car and have to have the TB on the back side of the intake as the front of the engine sits with a few inches of the firewall, so there is no room.
      Most people are using a FAST intake or factory intake reversed.
      Life is full of problems.
      It depends on how you deal with them and move forward.
      This will show others the type of person you are.
      Make the best of things that are put in front of you and enjoy life.
      Holley's website says the top can be mounted forward or backward.
      Oct 2012
      Waltham, MA
      Thanks, I guess I should have read though the everything first. This makes my life a lot easier. Now just have to hope it will fit with out to much extra body work.
