New to Pro-Touring
- Jun 2009
- 1
ls Engine mounts (pics) not aligning
Hello all, I am stuck in this conversion and thought I would ask for some help. My Ls3 motor mounts are not aligning up with the perches, I have done everything possible as far as shifting the trans and motor around.
The reason for this alignment issue is: I had to add a 1/2 Plate under the perches to help with the rack steering and raise the oil pan a little higher. Things look better after I added the plate under the perches but now the alignment issue.
I need help figuring out how to get it aligned, either adjustable mounts or a rubber/poly with a different bracket. not sure and any advice is appreciated. 1969 Camaro, ls3, t56 transmission.
Thanks Jason
