    Results 1 to 20 of 27
      Feb 2002
      Springfield, MO
      Done blowed up!!
      Well suck!! I have been fighting transmission woes for about the last year. I got it running again (but still not shifting right). I took it out today to see if the new modulator valve would fix the shifting part, it didn't. Well I ripped it thru the gears and at the top of 3rd I let out and saw a TON of white smoke in the mirror and the engine died. Coaste down a county road and popped the hood and water everywhere. Hoses still hooked up but overflow blown off. Started it back up to see and it ran really rough and smoking really bad. Hitched a ride home and got the truck and trailer, went back to pull it on and it hydrauliced so I had to push and use the straps to get it on. Came home and pulled the plugs and water came out of holes on both sides. Not good! Don't know if its just head gaskets or something deeper till I get it apart, which I'm not sure if I'm ready to jack with right now. It may get taken to my dads house and stuffed in his shop on the trailer for now.
      Suck!!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Sep 2007
      Denver
      bummer. Hopefully when you tear apart you'll find something as simple as a head gasket. Good luck
      David Beckstrom DVM
      oshawa ontario
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
      Aug 2012
      Warsaw mo
      that sucks.hope that it is just the headgaskets
      72' monte . Factory number matching 454.
      May 2002
      Northern California
      ouch, is this a new LSX? : p
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2002
      Springfield, MO
      LOL, nope just a lowly SBC!!
      Thanks guys. I was getting ready for an upgrade this winter anyway, but it wasn't jacking with the engine. I just bought a Truturn setup from ridetech. Heck, FedEx was pulling in the driveway at the exact moment I was backing the trailer into the driveway!!
      Jimmy
      Marshall , MO
      That sucks Jimmy, hope you get it sorted out. Hopefully just head gaskets.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Florida
      Sorry to hear. Pull the heads now and get the water out of the cylinders or it may become a much bigger repair than it might be now.
      Feb 2002
      Springfield, MO
      Good point. I went ahead and unloaded it into the garage. I'll start messing with it sometime soon enough.
      Jimmy
      California City Ca.
      sorry to hear, been there done that hope damage isnt to bad.
      Dale Hayes
      87 turbo t
      Atlanta GA
      Damn sorry that happened bro..
      Sep 2007
      Ventura, ca
      Bummer news. At the very least, crank it over with the plugs out and get as much water as you can out of the cylinders.
      I am not useless, I can still be used as a bad example!
      -Bob
      Jun 2012
      springfield, mo
      If you need to borrow a sump pump give me a call! Really tho, that sucks hard.
      Feb 2002
      Springfield, MO
      That you Eric?
      Jimmy
      Jun 2012
      springfield, mo
      Ya its me. Was the bigger turbos too much for it or was it just a failure?
      Feb 2002
      Springfield, MO
      Not sure yet, Hadn't pulled it out yet. Prolly wont be for a few weeks also since this weekend I am going to Laredo, TX to deliver a trailer load of wheelchairs to a church member that is going to get them into Mexico for handicapped kids that have nothing. Needless to say they ain't got "federal assistance"!!
      Next weekend we have our work CHRISTmas party and then all of the other festivities that go with December.
      Didn't know you were on here, gonna burn some turns with the Galaxy??
      Jimmy
      Feb 2002
      Springfield, MO
      Well, I actually got a wild hair and worked on the Camaro today. Ha a weekend that wasn't too packed or cutting wood, well had Saturday afternoon and night free at least! Started on it about 4:30 and got it out and on a stand and the heads off at about 11:00 by myself. I already had it on jack stands and the hood off tho. That's with dinner in between also! Not bad, I guess I have enough experience with it! DOOH!!
      Anyway, the #5&7 head gasket was melted between them, down by the lower water jacket hole. Don't know what would cause that really unless while I was ripping it and didn't notice that it had kicked the belt and got a steam pocket there or something. Never had one get 2 cylinders before.
      So, at least the cylinders are not split and it is an easy fix. But I'm wondering if I need to actually take it completely apart and Hone, ring and bearing it at this point. I don't want to have to go thru this again! Maybe even put studs in it instead of the Manly head bolts.
      Thoughts?
      Jimmy
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      I would defiantly put a machinist straight edge on it to make sure you don't have a warped head, or your block not square with the world.
      with at least a head gasket bad if there is more than 50k on the motor I would do a ring & bearing replacement & validate your balance & blue print.
      Feb 2013
      Airdire, Alberta
      I would stud it for sure with boost. I ripped a arp headbolt right out of the block on my 302 with 15lbs boost (pulled the treads out of the block). Head bolts just don't go deep enough into the block in my opinion, were a stud uses all the treads in the hole.
      Jun 2012
      springfield, mo
      Don't you think its time for an LS?
