    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 72
    1. #21
      Sep 2009
      Port Richey Fl
      The rear end from DSE came in with the Quadra link brackets. Moser 9" 3.89 with 31 spline Truetrac
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
    2. #22
      Oct 2011
      Katy, Tx
      Wow, I'm watching this build... This is looking great. Should be a real turner, heads and road course!
      Matt
      2015 Mustang PP GT
      Resto-Mod Coyote powered 1964 Fairlane 2 door post!
    3. #23
      May 2013
      Texas
      It really makes me appreciate the cars you'll find in the western states that have very little rust to be fixed. It cuts about the first three pages of a build thread down by not having that much sheet metal to have to document replacing.
      Great work so far. This one should be a fun to watch come together.
    4. #24
      Sep 2009
      Port Richey Fl
      Brian wanted something fun to work on so he started installing the DSE rear suspension. Part of the trunk floor has to be cut out.
      Installing the new DSE floor
      Rusty Gillis
    5. #25
      Dec 2013
      Denmark, North Jutland :D
      Country Flag: Denmark
      Cool project, cant wait to see the suspension on.. What plans do you have about wheels, and paint? :-)
    6. #26
      Sep 2009
      Port Richey Fl
      Quote Originally Posted by Protouringstang73 View Post
      I don't know what wheels the customer is going to use but I believe it will be white with the blue stripes like a Shelby.
      Rusty Gillis
    7. #27
      Dec 2013
      Sounds exciting, nice work you have done so far! :-)
    8. #28
      Aug 2005
      SF, Bay Area
      Looking good Rusty!
      1965 Chevelle. PM me about wheel tool rental
    9. #29
      Sep 2009
      Port Richey Fl
      Front cradle bolted in place and new DSE front mounts welded in place of the stock sway bar mount
      Holes drilled in frame
      Crush tubes that go in the frame
      Crush tubes bolt to the upper mount and will be welded to the frame
      Top bracket plug & tack welded in place
      Rusty Gillis
    10. #30
      Sep 2009
      Port Richey Fl
      You have to weld a snubber bracket to the frame rail
      Crush tubes welded in place
      Starting to fabricate a brace. DSE leaves the stock strut rod brackets but I like this better plus it gives you somewhere to place a jack.
      Rusty Gillis
    11. #31
      Feb 2014
      I like that setup in the front. I'm going to research that as I'd like to find one for a 62-65 Fairlane.
      Great work here. Keep it up. I'm interested to see the final product.
      Dave
    12. #32
      Jun 2010
      Houston
      Project is looking great! Which torque boxes dud you go with the 1piece or 2piece and were they the 65-66 vert boxes or the 67-68 coupe boxes. Thanks !
    13. #33
      Sep 2009
      Port Richey Fl
      Quote Originally Posted by kencobra View Post
      Two piece 68 torque boxes.
      Rusty Gillis
    14. #34
      Sep 2009
      Port Richey Fl
      Test fitting the front suspension
      Rusty Gillis
    15. #35
      Sep 2009
      Port Richey Fl
      The next on our list was to install the DSE rear suspension. It is a good thing they send a video and Brian bought a portable DVD player. This is what he is starting with.
      Rusty Gillis
    16. #36
      Sep 2009
      Port Richey Fl
      It has been awhile since Brian started installing the DSE rear suspension.
      You have to assemble the upper control arm bracket.
      Shock mounting bracket also welded in place
      Rusty Gillis
    17. #37
      Charlotte
      the RND into that front subframe must have been a small fortune.
      2014 Chevy SS LS3 / 4 Door
    18. #38
      Jun 2010
      Great thread as I'm getting ready to start my 65 fastback and this is the suspension setup I was wanting to do.
    19. #39
      Sep 2009
      Port Richey Fl
      Before Brian started the bottom brackets I sprayed a couple coats of epoxy
      The lower bracket is tack welded to the DSE torque box.
      Welded in place along with another bracket
      Rusty Gillis
    20. #40
      Sep 2009
      Port Richey Fl
      At one time the floor board had been worked on.
      Brian cut out the floor
      Cleaned the frame rail and epoxy primed
      New floor pan
      Sanded and ready for SPI black epoxy
      Sprayed a couple coats of black epoxy
      Rusty Gillis
