      Nov 2012
      louisville kentucky
      72 cutlass rear disc brake question
      I have a 72 cutlass with a bop 8.5 10 bolt. I'm wanting to do a junkyard rear disc brake swap. I've read about the ls1 camaro brakes on a chevelle but I'm pretty sure my axle flange is different. Anyone have any suggestions?
      Dec 2008
      Detroit
      That '72 should have the Corporate 10 bolt, the backing plates will bolt right up.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Nov 2012
      louisville kentucky
      Ok, thanks a lot!
      May 2010
      kitchener,Ontario,Canada
      I've got freshly powder coated 77-79 Cadillac Seville rear disc backing plates...dirty cheap they're on a twelve bolt now but will bolt on a ten bolt....to use them you need the same caddy calibers and disc's if you want 5on 5" bolt pattern if you want typical gm car 4.5 " I believe..use 79-81 firebird ws6 rear rotors..the whole set up is less then 200$ ..make a offer and the brackets are yours.
      Ryan [email protected]
