      Mar 2012
      Clutch problems bad
      ls2 -t56 swap 69 camaro clytch pedel is so hard flexinfg firewall..
      spec2 clutch
      american powertrain thowot bearing and master
      shimmed to specs
      no binding anywhere
      need king koing left leg
      HELP
      601 922 6891
      Mar 2012
      we are dirty
      Stuck
      May 2002
      Northern California
      could be a pedal ratio. can you post a picture of your pedal rod location?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Apr 2010
      Jersey Shore
      Start disconnecting hydraulic lines... See if the pedal moves freely with no line pressure
      -Chris
      '69 Corvette
      '55 Chevy Hardtop
      AutoWorks Middletown, NJ
      Mar 2012
      I have remove lines and works freely
      i can back trans bolts out 1/2 inch works fine
      now i am moving pedal rod up...
      Sorry i guess notification isnt working lol
      will be back in a while diving in again
      Mar 2012
      Add Content
      May 2002
      Northern California
      I remember some vendor sells a 1/2" trans spacer. Some units you have to verify bellhousing distance for proper release bearing operation.
      Mar 2012
      Clutch problems bad
      Twas the angle of the rod. Thanks
