Results 1 to 9 of 9
- Feb 2007
- USA, TN
- 850
Need help building a new rear end
I blew my 12 rear at the last autocross. Essentially, It started vibrating and I kept driving (dumb), then the pinion nut came off causing the pinion gear to eat the posi carrier. The rear in this car is the only original part left and is long over due for a rebuild. As I see it I have four options and more options within those four. I need lots of help selecting the right rear for how I use the car.
The car is a 71 Nova that is mini tubbed. Still has 255/45R17 tires, but plan to install 295/35R19 on Corvette rims (I have the rims) It also has a CA Chassis Works G-Bar suspension. The car is a daily driver with lots of autocross and some road racing. (I'm working to get my competition license by this summer). It has an LS3 eRod engine and T56 magnum. My 3.73 gearing is pretty good, but may change to obtain 150 MPH in 5th gear at 5800 - 6000 RPM.
Recent upgrades to the current axle: New Moser axles, Willwood DynoLite Brakes with P-Brake, and aluminum Dif cover. I really want to reuse the Wilwood brakes
Some questions:
1. What type of posi unit should I use. I don't mind a little noise for the sake of reliability. I have $500 - $600 for the Posi?
2. Should I insist on non C-clip axles. I just bought the new Moser axles, but I can sell them?
3. Can the factory 12 bolt be built to hold up to the use it will see?
4. Will I need a new drive shaft if I get a Ford 9 inch or Dana 60 rear.
5. I was looking at the Strange axle ends with 12 bolt pattern and 3.150 openings. How do these work?
My Options:
1 Rebuild what I have. Given it is an original GM 12 bolt, I'm sure it has some value. I think I still have the old axles too.
2. Buy a new 12 bolt from Moser or Strange.
3. Get a 9inch from Strange with the correct brackets from the CA suspension
4. Get a Dana 60
Need help guys. there are sooo many options and I'm not an expert. I have a $2500 budget, but can increase if I sell the old parts
