      Ontario, Canada
      Rookie coil over questions
      I am in the process of trying to set the expected ride height of my chassis and will be using steel tubing in place of the coil over to mimic the final ride height during my build.
      I emailed Strange to determine what the final ride height of the single adjustable coil overs would be and received the following response:
      The shock with the extended length of 17” will have a ride height between 13.875” and 14.50”. The shock with the extended length of 15” will have a ride height between 12.625” and 13.250”.
      My questions seem dumb, but
      - why are the ride heights of the two sets of shocks different (almost 1" difference between the midpoints of both), is this typical?
      - should I assume that the longer shocks are for the front as that is where most of the weight would be?
      - should I pick the mid-point in the ranges given as my preliminary ride height?
      Andy Pooni
      Beach Park IL
      Ride height....I have always used the 2/3rds method. Saving 2/3rds for compression. So let's say 3" total stroke, 2" is for compression, add 2" to your completely collapsed length and there is your ride height.
      Usually the longer shocks go on the rear because motion ratio is 1 to 1 in general, wheel moves 1" shock moves 1" But in the front you have a motion ratio of 1 1/2 to 1 or more so the wheel moves more than the shock therefore requiring less shock travel.
      That would likely be a good start.
      Donny
      May 2009
      Connecticut
      Andy I have the same shocks. I second what dontlifttoshift said, make sure you leave 2/3 of the travel for compression. If you manually check you will notice that the bump stops eat up some of your compression travel so you want to make sure you have enough.
      Aldin
      1969 Camaro (Weapon of Choice) in the works
      Ontario, Canada
      Thanks guys.
      Andy Pooni
