Thread: DIY progressive rate springs???
Well, I did a search and couldn't find anything like what I'm thinking, so I figured I'd post a new thread. Here's what I'm wondering:
First, and correct me if I'm wrong here, but progressive rate springs are progressive because the rate of the spring increases under compression. This is because the coils of the spring aren't linearly spaced (i.e. the number of active coils per inch increases in number from one end of the coil to the other). Basically, spring rate is dependent on the number of active coils assuming all other variable stay the same, right?
I started thinking about this and it occurred to me that it might be possible to "fake" a progressive rate spring, or more accurately, a 2 stage spring using spring clamps (which are the opposite of "spring helpers" you've seen in parts stores). The spring clamps could be positioned to section off the spring into 2 sections with an unequal number of active coils. The larger number of coils would have the softer spring rate and the small number of coils would have a higher spring rate. Make sense???
I've used spring clamps in the past without issue (even over long periods of time under hard driving conditions), so I feel ok about using 'em. The question is: does this seem to be sound logic? I certainly recognize that there wouldn't be any exact way to determine the rate of the 2 sections, but it could be tuned by changing the position of the spring clamps.
So, now to the real question: why bother??? Why not just buy progressive rate springs??? Other than being cheap (spring clamps are like $20 and progressive rate springs from Eibach run like $180), I can't think of really good reason... well other than the "tuning" think I mentioned previously.
Any feedback or thoughts much appreciated...
