      Oct 2010
      Florida
      461 stroker overheating in traffic
      I've tried just about everything and I'm convinced that it's the fan. I currently have SPAL dual electric fan setup supposed to pull 3250cfm. Radiator is 3 core champion. Temperature will usually go to about 200 and sit as long as i'm driving, but if i hit a few traffic lights, it starts to creep up steadily to over 230. (Luckily I haven't had to sit in traffic long enough to see how high it would go) Also, if I stop to get gas or something, once I restart, the temp. shoots up to like 230 until I get on the raod and am able to drive it for a while. I've checked/adjusted the timing, changed to 180 degree thermostat, new highflow water pump. Tested the radiator and its working properly, so it must be the fan right?
      I tried the factory style 5 blade steel fan in place of the electric fan, and it had little effect. I recently added an electric pusher fan because I have the vintage air a/c condenser in front radiator and I thought it might be blocking some airflow, but that too had little if any effect. I'm at a loss right now. Any help would be appreciated. Thanks.
      Feb 2008
      Texas
      Mine does the same thing like you said about putting gas in then you restart it and the temp goes up, but it will go down in a bit. That's all I can tell you, I have no idea why yours would be climbing up like that.
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      Jun 2010
      Georgia
      first, if you don't have your fans set to run based on temps when the engine is off, the temps will creep up when you shut the car off for a while until it cools down (this is why modern cars have the electric fans run for a period of time once you shut off the engine). This is because when you shut off the engine, all coolant flow and cooling stops, but there is still heat in the engine that has to dissipate. If you change the fans to run until the temp reaches a certain point, it'll stay cooler and will be better for the engine.
      Second, with the main spal fan, how do you have it wired? What type of controller are you using? Are you also using a relay? Those are some of the questions needed to go further.
      Also, the 3 core may not be enough for your 461 stroker based on size and horsepower. The big thing though is if you stay cool going down the road, for the most part your radiator is able to do its job. If it overheats in traffic or idling, then for the most part the issue is the fan(s). I would also suggest changing to a 195 degree thermostat, as those are better suited to warmer climates and 180's are better suited to cooler climates.
      Let me know about the above stuff, and I'll see if I can help with some pointers.
      Sep 2007
      Denver
      I had a similar problem with mine and had to be really thorough about preventing recirculating of engine compartment back around to front of radiator.When idling this is most important. Upper rad support to valence closeout, bottom rad to core support closeout,etc. Big motors create lots of heat and have to direct that hot air...just more critical and less margin of error than another smaller engine.
      David Beckstrom DVM
      Mar 2011
      Look into the Lincoln MKVIII fan as cheap fix. They are fantastic fans and can pull in excess of 4000 CFM. Tbirds and Cougars fans will work as well.
      $30 at my local salvage yard. Don't let the cheap price fool you. The DEW98 platform had a multi million dollar development budget. I'd rate a used MKVIII over any Chinese AM crap.
      Jun 2012
      How is your charging system. Those fans pull some good amps. Make sure your alt is up to the task.
      I have never had a problem cooling with those fans even is 100+ temps.
      What is the overbore on the engine some will just run how when the cyl walls get thin
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Make sure your fans are fully and well shrouded first. Wired correctly as well(moving in the right direction?) getting full power. Those fans should pull enough to, at the least, cool it under 220. Something seems amiss with the fan set up though.
      200 degrees at speed is OK but not great. Your radiator is barely keeping up, but worry about that later.
      Don't worry about the thermostat.
