    Results 1 to 17 of 17
      Oct 2005
      New Washington, IN
      1969 C10 Driver!
      This is my truck, thread titled Air Force 69. Am in the process of buying a new home and my drive is going to get even longer, so I need to get rid of one hot rod and get something with better MPG!
      As much as I hate to do it, I am putting my daily driver 1969 C10 for sale. This truck has a great history, bought new by the US Air Force and stationed at Bowmen Field for most of its life, as the mechanics truck for the Civil Air Patrol. I got the truck 3 years ago, drove it for 6 months then tore it apart for rebuilding. I pulled the bed and front end off the truck, striped the frame to bare metal and epoxy sealed it all.
      Front end.
      A Arms, spindles, and centerlink foo a mid 70's truck, bigger parts.
      The following are new,
      A Arm Bushing, polyurathane
      Inner and outer tierods and adjusting sleeves
      Upper and lower ball joints
      Inner and outer wheel bearings and seals
      6 lug conversion front Rotors
      Brake Calipers, hardware, hoses and pads
      Idler arm
      1.25" CPP Front Swaybar with poly bushings
      3" drop springs from CPP with 1/2 coiul cut off
      Poly bumpstops
      CPP Shock reinforcing brackets
      Toxic Front shocks for lowered application
      All Front Brake lines are new Stainless steel
      New Brake Master Cylinder and prop valve
      Rear
      Front control arm mounts flipped
      Rear control arm poly bushings
      CPP Full length Adjustable trck bar conversion
      CPP Rear shock relocators
      Toxic shocks for lowered rear
      CPP 5" Drop rear springs
      Poly Bumpstops
      1 piece driveshaft with new solid u joints
      Rear has 3.73 gears, fresh mobil 1 Synthetic fluid.
      New Blazer style rear mount gas tank conversion with new sending unit and Strainless steel tank to front fuel line
      Transmission is a 1960's Muncie M-20 wide ratio. Filled with Redline synthetic oil. Shifts very smooth. Has a Hurst Competition Plue Shifter and install kit.
      Interior has new reproduction black carpet. Full dynamat style sound deadner lining floor. New Stainless steal sill plates. New Grant Classic steering wheel and install kit. Summit 2 5/8" oil, water and volt gauges. 3 3/8" Mooneyes Vintage style tach. New interior rear view mirror, new glovebox liner, new pedal pads. Custom 6x9 brackets for behind the seat from 73-87chevytrucks.com Profile 4 channel amp under seat.
      Exterior has patina, mild rust as they all do but not as bad as most. Has new rockers tacked in, have new driver inner rocker not installed, and lower inner and outer patch for pass door not installed.
      DDM HID Headlight conversion and LMC Heavy duty headlight harness installed with 8000k bulbs.
      New high output horn.
      Engine is a fresh rebuild 355
      1978 010/020 block.
      New GM cast Crank
      New GM Powdered Metal Rods
      New SPeed Pro hyperutectic flat top pistions
      New Hastings rings
      New GM rod and main bearings
      New Comp Cam xtreme energy 234 cam
      New Howards Lifters
      New Comp Magnum Double roller timing chain with lock plate
      New GM oil Pump
      New Oil pan, timing cover and valve covers
      New ARP studs and bolts throughout
      New Felpro gaskets including One Piece oil pan gasket
      New GM Crate motor Heads
      New Edelbrock Performer Intake
      Numbers matching Quadrajet carb proffesionally built and modified for this truck
      New Proform HEI
      New JEgs mini starter
      New Alunimun Hi flow water pump
      New JEgs harmonic balancer
      New Hays 30lb flywheel
      New Crank and water pump pulleys
      Engine has only seen Brad Penn Oil
      New 94 amp alternator , truck converted to internal regulator
      New 3 Row Aluminum Radiator, new radiator mounts
      New 16" electric fan on a thermostat shwitch, no mechanical fan
      New Exhaust system. 2.25" manderl bent with thrush 2 chamber mufflers and h pipe dumps behind rear tires with 2010 Camaro tips, sounds killer!
      Way more details to share! Tons of recipets!
      The truck was put back on the road in August. Everything was new never used before then! I have put almost 4000 miles on it since then! I drive it 70 miles round trip everyday to work. It runs great, 52psi of oil, nver gets above 200f with a 195 thermostat and the fan switching on at 200. Gets about 14 mpg now. A t5 swap would get it closer to 20. I'm gonna do this swap if it doesn't sell, only reason for selling is due to the commute and buying a new house, and could use some cash.
      Also has NEW 235/60/17 Tires on 17" wheels. Stock wheels with tires as well.
      Go to protouring.com and look up AIR Force 69 for the details and pics on this truck.
      Feel free to email me with questions, I can send pics having issues getting them here.
      I am not desperate to sell. Prefer cash but will consider partial trades on other GM stuff, camaross firebirds malibus s10s of interest.
      $6500!
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      Oct 2005
      New Washington, IN
      Here is the thread.
      https://www.pro-touring.com/showthre...2-Air-Force-69
      As of right now, I am driving this truck daily, about 70 miles round trip. Does great, just using a little more gas than I can afford. A T5 swap is the key, but I don't have time and am looking at another house that will add to my commute!
      Oct 2005
      New Washington, IN
      Indiana
      Good looking truck! I vote you keep it and find a cheap commuter car because you know you're going to miss it!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Oct 2005
      New Washington, IN
      Quote Originally Posted by Yelcamino View Post
      Thanks, and I agree, but I'm just too poor to have all these hot rods, and the Camaro will never leave, so its this one. Hey, its not too far for you, perhaps ridetech could use another? I'll take partial store credit!
      Aug 2010
      New Albany IN.
      I see you're a local guy. Nice truck good luck with sale
      Oct 2005
      New Washington, IN
      Yep, thanks.
      Stuff not mentioned in post,
      new motor mounts and transmission mounts
      New clutch pressure plate and throwout bearing
      New clutch pilot bushing
      New exterior mirrors
      New lug nuts, extended lentgh rear wheel studs
      New stainless steel bed mounting hardware
      Feb 2007
      great truck for the money. Wish I had the cash. good luck with the sale. Bump
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Oct 2005
      New Washington, IN
      Quote Originally Posted by brownz View Post
      Thanks! I'm getting some interested parties. Kinda suprised, guess i should have started at a higher price, I really don't want to seel, but I need too.
      Indiana
      I'll be back from Cali on dec. 1. If you've not sold it by then, we'll talk. Nice truck!
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Oct 2005
      New Washington, IN
      Quote Originally Posted by bret View Post
      Sounds good!
      Oct 2005
      New Washington, IN
      Its wierd, in the last 3 days since I put this up for sale, I have had more random people on the street come up to me and say how much they like this truck, then in the past 2 months of driving it! It must be a sign.
      Looks like I have a couple non locals interested in it though, so we'll see what happens.
      Oct 2005
      New Washington, IN
      truck is supposed to be leaving for its new home today! Will post when its confirmed for any interested parties.
      Got a lot of interesting trade offers.
      Oct 2005
      New Washington, IN
      Truck is sold and on its way to Charlotte North Carolina!
      Central, Ky
      2003 Crewcab Dually Dirtymax
      1980 Malibu...6.0 LSx turbo on the stand.
      2000 SS th400 little juice
      2002 C5 glide swap, motor shopping
      1970 Nova... still waiting.
      Feb 2007
      Congrats on the sale. someone got a nice truck!!
      Brandon Slater
      1979 Z28
      1972 Nova
      Thomasville, NC
      (x2)
      1966 Pontiac Catalina Ventura
      389/TH400, Wide-Track Darksider
      Bars, springs, disc brakes, etc.
      1962 Falcon 2-dr
      "just getting started"
