    Results 1 to 16 of 16
      Nov 2012
      1968 Pontiac Firebird Resto Modded Project Car
      MORE PICTURES AT BOTTOM OF POST
      VIN: 223378U607666
      CLEAN TITLE and TITLE IN HAND
      [COLOR=#000000][FONT=Times][B]I am selling a 1968 Pontiac Firebird Project $14,000 OBO NASHVILLE, TN **Price Drop**. I have been building this car over the past few years but due to other responsibilities was not able to complete as planned. Most of the parts are brand new out of the box which includes receipts (0 miles, used for assembly only). The most attention the car needs is body work, but with the parts supplied and some TLC this car has great potential. I am basically just try to pay for my drivetrain the body is free and if the buyer is interested in the rotisserie they can take it as well. If you need any additional pictures or questions answered please feel free to contact me at Alexander - 615-405-3578 calling or texting is fine. Below is a list of parts and labor in detail. I am also open to trades. trades + cash(on your end) preferred I am open to trucks, suvs, cars, beaters, etc...
      Body
      • Chemical dipped in Indianapolis, Indiana
      • Year One body panels bought brand new
        • 2 quarter panel
        • 2 inner fender welds
        • trunk pan
        • deck lid
        • door skins
        • fenders
        • inner fenders
        • fender extensions (6 months back order)
        • hood
        • radiator core support
        • 2 floor pans
        • windshield
      • Custom fabricated motor mounts for better weight distribution
      • Original driver and passenger glass as well as rear window (no quarter glasses)
      • Custom made 3 piece rear spoiler
      • 1969 Camaro rear bumper cut to fit
      • Gas tank with straps
      • Front bumper
      • Full stainless steel body bolt kit
      • New left and right front grilles
      • Weather stripping
      • Shaved door handles
      • Shaved drip rails
      Suspension- Powder coated
      • Heidts 0 miles
        • front subframe
        • spindles
        • upper and lower control arms
        • front sway bar
        • subframe connectors
      • Wilwood 0 miles
        • 4 piston calipers all around
        • 13 inch brake rotors all around
        • wheel bearings
        • brake pads
      • QA1 coilovers all around 0 miles
      • Energy Suspension body mounts all around
      • Strange Engineering 0 miles
        • 4 link rear suspension
        • custom ford 9 inch rear end with 373 gears
        • 32 spline axels
      Engine
      • 1975 Pontiac Grand Prix 455 big block 0 miles
        • block and crank bored .030 to 4.181 "bore, stock stroke 4.210"
        • block has been tapped for screws in oil galley plugs. the lifter has been deburred also
        • crank has oil feed holes
        • crank turned .010" on main rods
        • stock connecting rods with Badger pistons and speed pro rings
        • speed pro rod, main cam bearings, fel-pro gasket set
        • summit timing chain, and oil pump 60lb pump
        • Comp cam magnum 280 cam and high energy lifters- cam spec- .480 lift, 280 duration 110 lsa, 106 intake centerline
        • Comp magnum roller tip rocker arms- 1.52 ratio
        • 6x-4 heads, 89cc combustion chambers, 9:2:1 compression ratio- rebuilt with new guides and seals, valve job, resurface and Crane valve springs
        • Edelbrock Performer RPM intake, exhaust crossover blocked with stainless steel plates
        • holley 750 cfm double pumper carb- race prep, stock jets, HP main body upgrade
        • stock distributor with summit rebuild kit and summit plug wires, AC delco R44ts plugs
        • holds 6 quarts with filter change 15w-40
        • stock starter
        • Headman headers
        • Flowmasters exhaust
      • OE slave cylinder, clutch reservoir and brake reservior
      • Oil filter relocation kit
      • Painless Wiring Harness (front to back)
      Drivetrain
      • Unisteer rack and pinion 0 miles
      • Summit racing steering column without tilt
        • Flaming River connections
      • Steering wheel
      • Tremec TKO 5 speed 0 miles
        • 550 horsepower clutch and pressure plate upgrade 0 miles
        • billet aluminum flywheel 0 miles
        • Scatter Steal upgraded bellhousing 0 miles
        • Hurst shifter and shift knob
      • aluminum driveshaft 0 miles
      Rims and Tires
      • CCW Classics 0 miles
        • 17x9 275 Front
        • 17x95 285 Rear
      Miscellaneous
      • handful of original parts
        • window regulators
        • trim pieces
        • pedals
        • tail lights
        • cowl panel
        • hood hinges
        • hood scoops
        • door hinges
      • Interior
        • both front seats
        • rear seat cushions
        • door panels
      Pictures
      [LIST]
      Pictures
      Before
      3 months ago (the furthest I got)
      As it sits now
      MORE PICTURES HERE http://www.firebirdnation.com/forums...-resto-modded/
      Jan 2012
      Va Beach
      What body work is left to do?
      Nov 2012
      Quote Originally Posted by Grifter757 View Post
      Basically almost all of the body work is needed. barely got started
      Nov 2012
      up!!
      would you sell the rotisserie?
      pm me the $$
      Nov 2012
      ^^ let me see if I can sell it as one. If not I will PM you a price
      Nov 2012
      price drop bump
      Nov 2012
      bump Merry Christmas
      Jan 2013
      Quote Originally Posted by tennhouse View Post
      is the car still for sale ? How Much? anything else done to it?
      Nov 2012
      Yes the car is still for sale. I will take $15,000 OBO. No, still looks the same as pictured above
      Nov 2012
      Still for sale.
      Nov 2012
      super bowl bump
      Nov 2012
      bump updated PICTURES
      and price drop!
      Feb 2013
      Nice to finally talk to you on the phone Alexander. I'll see you shortly to pick up my new project. - Don
      Sep 2011
      Palmdale, CA
      still for sale
      Nov 2012
      White House TN.
      My father in law works for his dad, he told me he sold it.
      68 Impala 396/325
      69 Camaro 327/4sp
      64 corvette 327 4sp
    Tags for this Thread
