    Results 1 to 16 of 16
      Aug 2012
      Indianapolis
      1964 Ford Falcon- Project LONG term
      So here is my 1964 Falcon:
      It was an original 170, 3 spd car that has been changed to a 289 and C4. This was not done by me and the front end was left with 4 lug drums and 6 cylinder steering. I am in the process of updating this and it is going to be a long term project.
      This winter I am going to pull out and replace the leaking C4.
      It has turned the undercoating to goo so that will be stripped off and addressed this winter and I am leaning towards coating it with Eastwood’s Rust Encapsulator.
      While taking the headers off I also found a broken motor mount:
      The Strut rods are also shot:
      So my plans for this winter include: all new steering parts with an upgrade to V-8 parts. I'll be replacing the column with an IDIDIT collapsible one, I'm contemplating a rebuild on the steering box but it is pretty tight and I haven't decided. New UCA and LCA, Granada front disc brakes, roller spring perches, new springs and adjustable strut rods. While I was debating on doing coil overs and it that is more of the pro-touring, I have to save money on this project as making this safer for my family is my main goal. Also my Dad gave me the rims off of his 2003 Mustang V-6 convertible that ar 16x7. I think they will look good on her (minus the pony of course!):
      So this is just the beginning and while I don't know how to weld, I hope that by the end of this adventure I will. Watching all of your projects gives me some serious ambition and that is why I started this tread. Hopefully I will add more modern touches as I go. Eventually I'd like to get a manual back into the car, do rear disc brakes and change to a more modern setup in the rear.
      Nate D
      64 Falcon Futura
      Feb 2011
      Indpls, IN
      Nate,
      I'm in Indy also. South side of town. I have a 65 Falcon.
      I have some parts that may be of use to you. No charge, I was just going to scrap them. PM me if your interested.
      BTW, Nice car.
      Steve
      san diego
      The falcons are taking over! Watch out camaros.
      Feb 2011
      Indpls, IN
      Thats right, we only need about 50 more Falcons. LOL
      Mar 2010
      New Jersey
      Name:  right stance.jpg
      Quote Originally Posted by Jetfixr320 View Post
      I'll add mine but I'm not sure it'll count....
      fordtc87, love the car. Keep the progress and pix coming!
      Dec 2010
      It looks like you've got a good starter--try to stick to changes that offer genuine/proven improvement, rather than bling. Both your driving experience and wallet will be much happier with your choices. Do note that the original strut rods are actually adjustable--they are no less adjustable than something you'd pay 4-500 dollars for. Check out Cobra Automotive's site, if you haven't already done so; they regularly have millions of dollars worth of highly successful vintage racers in their shop, and most of what they use is not all that trick. You might also look up Evergreen Performance, who work on the "Mighty Falcon," which has won many times at Pike's Peak. My suggestions are not so much for encouraging you to build a race car, but to encourage making choices that are not so much influenced by pretty pictures and marketing...
      Texan Back in Texas!
      Woot! Falcons represent! If you have questions we are out here to help.
      1965 Falcon Hardtop
      Aug 2012
      Indianapolis
      Thanks Guys, we are adding up here in the pro-touring world! The more Falcons the better!
      Rustomatic- thanks, I am heading to check out those websites. I know you're not trying to help me build a racecar but I want the car to have a car that can handle some twists and turns. If you know of more things let me know, the more resources the better I can make an informed decision.
      Nate D
      64 Falcon Futura
      Batesville, IN
      Cool project - - -I'm in Batesville, IN........ Go Hoosiers (as in residents of Indiana). I'm a Purdue Grad!!!! ;)
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Aug 2012
      Indianapolis
      Hey Everyone, Merry Christmas, Happy New Year, Happy Festivest, etc, etc. Anyway I haven't disappear, and I've been busy on the car. So far I have been scraping the heck out of the underbody coating that is on the car. I have become way too familiar with my scraper and heat guy. I now have the complete front suspension removed:
      I also have been playing around with the rims my Dad gave me (sorry for the messy garage, between the kids stuff and my work stuff I don't have enough room!)
      I also was blessed by Santa for being a good boy! (a BIG thank you to my wife!)
      I got a new IDIDIT steering column, UCA, LCA, Roller Spring Perches, Springs, CSRP granada disc brake swap, centerlink, idler arm and all the stuff to swap this over to V8 steering.
      Now I have to decide what to do the wheel wells with, I have an internal debate between POR-15, Eastwood products and the KSB Rust Seal. Any input would be appreciated. I feel that I should top coat the POR-15 as it will see some UV light in there. I'd rather be safe than sorry. Alright, hope your projects are going, thanks for checking mine out!
      Nate D
      64 Falcon Futura
      Aug 2012
      Indianapolis
      Resurrecting this thread
      So after building a new house and having a 3rd son I am finally in a better position to work on this project. What started as fixing the front end and trying to determine why a C4 was leaking all over the place has led to a much more detailed restoration/build.
      I pulled all the carpet and found the PO glued rubber down to the interior floor to keep,it from leaking. This created some rust issues in the floor pans but not all that bad. Just a crappy fix.
      Then I got under the car and started to scrape the underbody coating off. If anyone ever recommends doing this to a car DON’T. I have spots that have rusted under these. There was a piece of heating pipe shoved in this hole before the undercoating was sprayed. Another hack fix...
      I found the rear frame rail on the driver’s side by the torque box to have rust issues. Just add to the list!
      So I started repairs. Learning to weld and started with the passenger front floor. Not the greatest but a learning experience. I’m getting good at grinding, welding has a ways to go!
      I pulled the rear end out and got some help from JetFixr with pulling the engine and transmission as well.
      Then he knows a guy with a rotisserie and he let me borrow it. This thing is a miracle!
      Now I can scrape the coating off without laying on my back. So much easier!
      I’ve found an oscillating tool with the scraper attachment works best. This was my pile from New Year’s Day.
      So I’m making progress. Kind of going backwards to get forwards but I feel good about what I’m doing. I am not sure what I am going to do with the engine, transmission at this time but I want to just have this out and driving in the next few years. I’m trying to set realistic goals!
      Happy working on your projects and thanks for the support and a big shout out to Steve for the help to,get here!!
      Nate D
      64 Falcon Futura
      The Netherlands
      Country Flag: Netherlands
      Nice Falcon! It all looks so familiar... I have a 62 Nova, structurally it is very similar to a Falcon. I had mine in a rotissery too, never again will I do a job like that without one! Keep up the good work :-)
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      May 2017
      Nice work and jealous of your rotisserie
      Feb 2011
      Indpls, IN
      Nate,
      Glad that I could help! You will be making some progress now!
      Steve
      Aug 2012
      Indianapolis
      Small steps
      Martin- I really dig the Old Novas too. A rotisserie is so worth it. I wasn’t sure if I’d ever get to use one. Thankful for friends!
      Boosted, keep it up! I think an Eco-Boost is a cool choice for an engine. I know in my Dad’s 2014 F 150 it’s a fun engine to drive. In a light weight Falcon, it’ll fly!
      I just about have all the underbody coating off. Started to fix some of the Swiss cheese I’ve been finding.
      This is in the rear footwell. The rear frame rail starts here.
      Cancer removed
      Patch made. I have it test fitted and I’ll weld in later this week.
      Nate D
      64 Falcon Futura
      Dec 2011
      Hey, got any updates on the Falcon ?
