Thread: Needing help with electmotive fi
11-09-2012 #1
- Jan 2011
- Greenbrier, AR
- 5
I have a 72 pantera with a 351 Cleveland with electromotive fuel injection . The problem we r having is at 4800 rpm the car goes lean and falls on its face ( at 4800 not about). The car is not running out of fuel or loosing fuel psi but if u let off the gas alittle the car will start pulling . We have set the UAP way bigger than it is suppose to be and have added 50% fuel in the correction table and nothing makes any sufferance good or bad. Some info on motor is cam is 252 264@ .050 106 lsa, twm individual tb, old c3 heads, 65# injector, Waldron 255 fuel pump, 180 degree headers. Drive ability and ideal is good just wide open throttle is prob. Don't know if cam could be some of it or what just needing some different opp. Thanks
