    Results 1 to 9 of 9
      Nov 2012
      ocala fl
      tunnel ram with dual tp doable???i
      what system would be better and how bad would dual tpi,s hurt gas miliage this car will be a daily driver 496 bb chev muncie 4 speed 350 ford 9" tire size of about 25 1/2 in tall in a 66 lemans conv
      Oct 2006
      NJ
      It's very good option. You can run either twin TBI's or dual air valves with port injection below. While either setup can be tuned better than carbs for economy...the sequential port injection would get the edge.
      Dennis
      Moore Racecraft
      Jun 2009
      Piqua, Oh
      I agree with Dennis, but with a 496,are you really worried about gas milage? With that in mind, you spend your money better on a good OD transmission.
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
      Oct 2006
      NJ
      No doubt the OD and EFI would be an ideal combination. Especially w/ a lockup converter. I've bested 12.9mpg on e85 w/ 572" Twin Turbo BBC. Granted it has a very mild cam and not much gear needed. I've spent alot of time working on fuel milage tuning...it takes some work but worth the effort in the end.
      Dennis
      Moore Racecraft
      Aug 2011
      Clearwater/FL
      Quote Originally Posted by 64duece View Post
      I'd say that's impressive considering it's on e85...
      88 Blazer sbc
      05 300c
      Dennis,
      I assume this was with the new Holley Dominator system?
      Oct 2006
      NJ
      Dennis,
      Correct...it shows real time fuel economy as the system knows fuel/lbs hr and speed from the 4L80E. I back that up with the normal milage vs gals as well...worked out nearly spot on.
      Dennis
      Moore Racecraft
      Miami, FL
      dual quad EFI
      very doable
      Jun 2006
      Katy,TX
      I remember seeing a few years back a Hemi dual quad where they plumbed the injectors underneath and modded some carbs to just be air valves with a TPS.
      1965 GTO project car
      2004 Pulse Red GTO
