    Thread: LS2 vs. LS3
      Jun 2009
      New Hampshire
      LS2 vs. LS3
      Hey Guys, I have an opportunity to purchase a salvage GTO with an LS2 which has LS3 heads installed and an LS3 intake. It is for much less money than an LS3 take out so I am wondering if there are any major differences other than the .2 CID, between the short block of an LS2 and an LS3?
      I'm thinking if I go this route I could run this until I blow it up and\or raise more money for an LS3.
      Thanks, Matt
      Birmingham, AL
      I don't think you will see a big difference in power. if the cost is dramatically different I would go with the LS 2. I upgraded to an LS 3 but it was only because I had an iron block engine and wanted to upgrade to an aluminum block.
      Stephen
      Sep 2011
      Lubbock, Texas
      There isn't a huge difference there. You will see a lower compression ratio because of bore size on the LS2 compared to the LS3, but all in all very little difference.
      Oct 2007
      John. I bet you forgot more about LS engines then I will know in a life time, but I read the LS3 was a better breathing engine with more potential then the LS2? IS that just internet Hype ?
      67 Camaro In progress
      Metamora, Illinois
      Quote Originally Posted by XLexusTech View Post
      That has to do with the cylinder heads not the shortblock and why you see a lot of people putting an LS3 topend on an LS2.
      Jun 2009
      New Hampshire
      thanks guys
      Sep 2011
      Lubbock, Texas
      That is correct! One thing to keep in mind is that the LS3 top end will kill some low end due to the compression and port velocity loss. Those heads breath more because of a pretty large intake valve and intake runner but lose low end for the same reason.
