    Thread: 17 vs 18
      Aug 2012
      17 vs 18
      I have a 1971 Camaro that I am building for track days. I am planning on using a 315/30-18 tire in the rear. Wheel selection is difficult and expensive for this, however, 315/35-17 opens up more options. Both tires and wheels are cheaper. Since the tire diameter remains the same for the 2 tires I am hoping someone can tell me if I will notice any difference from he drivers seat. My assumption is "no" but I would like to hear from anyone who has done this.
      Beach Park IL
      On paper, the 17 will give you some more time before the tire "goes off" than the 18 will. The 17s will ride better with more sidewall. Weight should be a wash between the two.
      The 18 will offer much better tire choices now and in the future......although if current trends continue 19s will be the standard rear wheel diameter in the future.
      You really can't make this decision independent from the front. If you have determined that a 17 will fit your needs in the front, great. If you haven't then you need to decide that first. Without knowing your suspension plans its hard to say, but most aftermarket subs frames work best with an 18" wheel.
      Donny
      Aug 2012
      The fronts will be 275/40-17 or 275/35-18 using a stock subframe. Once again, the tire diameters are almost identical so the fit should be the same.
      Colorado Springs
      The caveat I'd throw in to this consideration is...if you chose a 17 or 18 inch size that was originally offered by an OEM, then tire selection will remain longer than whatever custom aftermarket size you may be considering. The aftermarket regularly changes sizing. However, if you pick a size that was offered on Vettes, Vipers, Mustangs, or Camaors, the market will continue to produce rubber in those sizes for a much longer time.
      TonyC@HP2
