    Results 1 to 12 of 12
      Nov 2011
      Tennessee
      1970 nova tire size
      Will a 245/45/18 fit on the front with stock sub frame lower a lot top of fender to top of rim with no rubbing . Wheel is 18-9 with 5/5 bs any help would be great before we order
      Nov 2011
      Tennessee
      That's a 18-8 wheel sorry
      Hildebran, NC
      I have a 245/45/17 on a 8" rim with 5.25 backspace.
      It fits inside the fender / fender well / frame very good.
      My set up does not rub on the road at all.
      I also run -1 deg camber as well. This helps to keep the tire away from the top of the fender edge.
      Randy
      Nov 2011
      Tennessee
      Thanks randy anymore info would be great just starting to build a nova and want to get the stance right.would like to get it as low as possible
      Cincinnati Ohio
      With the right parts you can run a 275.
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Hildebran, NC
      Quote Originally Posted by Jenkins View Post
      I have DSE: UCA, LCA, 2" Drop Coil Springs, Koni Shocks, 2" Drop Leafs & 1-1/8" block in rear.
      I actually have a 3/8" coil spacer to get the car back up a little in the front.
      My drivers side header is about 2-3/4" off the ground. Frame is at least about 4-1/2" off the ground.
      I am looking to do a motor swap soon, and will be looking for a tighter fitting header to the body.
      Randy
      Hildebran, NC
      Quote Originally Posted by Bad94 View Post
      Absolutely!!
      I put some on my wheels and they were a little to close to the outside lip. If i went to a 9" wide & changed the BS, this would definately work.
      I will run 255s on the rear when my KDWs wear out.
      Nov 2011
      Tennessee
      Randy do you have any pic you could send to bryanjenkins1969@gmail .com. I'm trying to get the look like billy ulteys nova
      Hildebran, NC
      Check your inbox!!
      Nov 2011
      Tennessee
      Thanks randy for the pic
      Oct 2007
      I am currently mocking up a 245/45-17 mounted on a 17x8" 4 7/8" backspace wheel on my '71. I do have a Wilwood brake setup that pushes the wheel out some small amount as I understand it. I haven't gotten back to it yet to run the wheel through the range of travel but just from eye-balling it I think it's going to be extremely close to getting into the fender when the wheels turn. I'm hoping I'll have some time to work on it this weekend. However with a newborn that time is hard to come by .
      Randy, do you have any pictures that show how far your wheel sits in from the fender edge?
      John
      Nov 2011
      Tennessee
      I'm trying to get a look like billy ulteys nova he said he runs a 18-8 on front with a 5.5 bs. Just trying to get mine low
