Results 1 to 15 of 15
Thread: voltage at starter
10-19-2012 #1
- Aug 2009
- 47
voltage at starter
Testing my wiring before initial start up. Setup is trunk mount bat. With cutoff switch and ford solenoid. Passes thru bulkhead with bulkhead fittings. Using double ought wire. Only getting 11.78 volts at bulkhead fitting and still have the run up to the robbi MC starter. Is this voltage drop normal. Is it a.concern with such a long run to go? Should I be worried about amps and not volts?
Steve
