Results 1 to 11 of 11
Thread: Help with idle - holley 4150
Need some help - suggestions - direction to go.......
been having issues with the edelbrock carb leaking so i rebuilt the Holley 4150 i had on the bench
its a 4150 double pumper with a 750 body with no choke and i used Holley rebuild kit to do the job
problem is it's idling around 2800 rpm ??
here is what i have tried so far
- turn down the idle screw all the way down
- checked linkage and made sure the throttle was not being held open
- when i 1st started it fuel puked out of the top vents so i have now dialed the float adjustment all the way down
- i adjusted the idle mixture screws town to 1 1/2 turns on each side
suggestions please -- thank youDon
Grace - 67 Camaro daily driver with upgrades along the way.
https://www.pro-touring.com/showthre...-Camaro-Driver
