    Results 1 to 9 of 9
      May 2010
      Mooresville, NC
      Holley HP EFI Help Needed
      Just wired up the Holley HP EFI system. When I connect the battery posts to the terminals, I can hear the fuel injectors firing. This is with the ignition key off. What is causing this?
      Car: 1969 Camaro
      Motor: 2009 LY6 6.0 58X reluctor wheel
      Cam: Ultradyne 223/230 VVT delete with LS3 Cam cover and 4x 3 bolt cam
      Intake: Stock LS3 with stock injectors pulled off a 2011 Camaro w/LS3 MAP
      Throttle Body: Edelbrock 90mm DBC
      FEAD: C5
      I am using the Holley LS2 HP EFI part number 550-603
      I hooked up the Holley harness as follows:
      Red wire: to battery
      Red/white 18ga wire: 12v ign switched at fuse block
      Black 18 ga wire: chassis ground
      Green wire: fuel pump relay
      Computer power harness: POS and Neg wired to battery
      Blue/white wire: not hooked up yet
      I am not sure why the injectors are firing? Am I missing something obvious? Any with experience with the Holley EFI systems that could help would be greatly appreciated. As far as I can tell everything is wired per the diagram provided in the CD.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Jul 2011
      Did u talk to Holley tech support ???
      Aug 2008
      jacksonville,fl
      X-2 on holley tech help. I,d guess either a problem with the sensor triggering the injectors (shorted ) or a computer problem.
      Add on systems aren't very complicated to wire , as you know.Probably not something you did.
      May 2010
      Mooresville, NC
      I posted on this forum and did get my question answered quickly.
      http://forums.holley.com/
      Engine is running great now, about to start tuning her.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Aug 2008
      jacksonville,fl
      May 2010
      Mooresville, NC
      Had a connector grounding out on the positive wire to the battery. I had everything hooked up temporarily just to get the engine started. I pulled everything apart and re did it with heat shrink and it's now working perfectly.
      If anyone needs help with Holley EFI, I would recommend the forum. There is a user named Danny Cabral who is very helpful (not sure if he works for Holley?). Holley could definitely benefit from hiring a few more people to answer the EFI tech line phone. It is very frustrating trying to get ahold of them. With that being said, The Holley HP EFI kit is awesome! I would definitely recommend it to anyone over using a factory harness and ECU.
      Marc Battiste
      1969 Camaro
      LY6/T56/12 Bolt
      Jul 2011
      Quote Originally Posted by regal454 View Post
      I have been very happy with my Holley efi dominator!!im getting ready to add my kenne bell so it should help a lot with self tune fuel tables!!yeah Holley forums, I don't think they do much with!just call them, it's quickest!!
      Nov 2009
      Austin Texas
      How is the holley efi setup running?
      Nov 2011
      Riverton, Wyo,
      I have been on that forum as well, Danny does not work for holley, I asked. He is pretty sharp guy.
